Skullcandy Crusher Wireless Battery Replacement
  1. Skullcandy Crusher Wireless Battery Replacement, Ear Cushion: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Skullcandy Crusher Wireless Battery Replacement, Ear Cushion: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take your headphones and hold them upside down for better control with your hands.
  2. Skullcandy Crusher Wireless Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Skullcandy Crusher Wireless Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
    • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
  3. Skullcandy Crusher Wireless Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
  4. Skullcandy Crusher Wireless Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Skullcandy Crusher Wireless Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion of the headphones.
    • You have to work on the right-side earphone.
  5. Skullcandy Crusher Wireless Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Skullcandy Crusher Wireless Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Skullcandy Crusher Wireless Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
    • Gently pry the speaker part away from the frame of the headphones.
  6. Skullcandy Crusher Wireless Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Skullcandy Crusher Wireless Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the headphone speaker assembly from the headphone speaker frame.
  7. Skullcandy Crusher Wireless Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Skullcandy Crusher Wireless Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Skullcandy Crusher Wireless Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery from the headphone housing.
    • Use a soldering iron to desolder the black, red, and yellow cables from the board and disconnect the battery.
    • For more information on soldering, please, use this Solder and Desolder Connections guide.
    Buenas, excelente tutorial. Sabes que modelo de batería es la que tienen los skullcandy crusher?
    Mauricio Crivelli - crwdns2934203:0crwdne2934203:0
    Supiste qué modelo de batería es ?
    Juan -
    Buenas, gran trabajo.
    Sabes cuál es el modelo de la batería o que tipos de baterías podrían suplir la original, gracias
    Alfredo2345 - crwdns2934203:0crwdne2934203:0
    Soooo..... whats the model and type of the battery???
    Hugo Varo - crwdns2934203:0crwdne2934203:0
crwdns2935229:05crwdne2935229:0
Val
crwdns2935283:003/31/22crwdne2935283:0
1.178 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-33, Gurgel Spring 2022 crwdns2935289:0UMass Dartmouth, Team 1-33, Gurgel Spring 2022crwdne2935289:0
UMASSD-GURGEL-S22S1G33
crwdns2935297:013crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Hi, Can you specify this replacement batterys name and model number?
kituserkituserkituser kit - crwdns2934203:0crwdne2934203:0
1050mAh, 3,7V 3,885Wh
Mika Björn Wilhelmsen -
Which battery should i buy for my skull candy hes evo??
Lakshit Meena - crwdns2934203:0crwdne2934203:0
donde puedo conseguir la bateria de los skullcandy crusher?
y cual bateria lleva?
pedro landeros - crwdns2934203:0crwdne2934203:0
Am I able to send my headphones to you to be fixed?
If I can, what would the cost be?
I have two headphone sets
Jeffrey Timothy Valerie - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 54
crwdns2936753:030crwdne2936753:0 243
crwdns2942667:0crwdne2942667:0 12,386
