Siemens coffee machine Water Tank Seal Replacement
  1. Siemens coffee machine Water Tank Seal Replacement, opening procedure: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug your coffee maker!
    • Remove the water container, the brew group and the drip tray with pomace container.
    • Using a spoon, remove as much of the coffee beans as possible from the coffee bean container.
    • Depending on the model, additional sensors with cables may be installed on the top and side panels. You have to remove these before you can completely remove the housing parts.
  2. Siemens coffee machine Water Tank Seal Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Torx T10 screws on the top.
  3. Siemens coffee machine Water Tank Seal Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Siemens coffee machine Water Tank Seal Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove seven T10 Torx screws on the back.
    • The two screws at the bottom of the front can remain.
  4. Siemens coffee machine Water Tank Seal Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Siemens coffee machine Water Tank Seal Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press with a flat-head screwdriver into the openings on the side with the water tank. This releases the latches on the top.
    • Press the flat-head screwdriver into the opening on the side with the brew group. This will release the last notch on the top.
    • Lift the top off.
    • On some models, a cable leads to the sensor on the powder tray. Unplug the connector on this cable first.
  5. Siemens coffee machine Water Tank Seal Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Siemens coffee machine Water Tank Seal Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the side section of the brewing unit about 2 cm to the rear. This sometimes gets stuck and may require some force to remove.
    • Remove the two tabs from the power switch.
    • Take off the side panel with the brew group.
  6. Siemens coffee machine Water Tank Seal Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Do the same with the panel on the other side.
    • To remove the water tank hose simply pull it of the pump.
    • Remove the side panel.
    Hallo, das ja ganz tolĺ erklärt. Ich brauchte ein Bild von dem Elektronicteil wo man die Kabel sieht in welcher Buchsen Sie stecken.Danke.
    Bernd Bennewitz - crwdns2934203:0crwdne2934203:0
    Bei den anderen Anleitungen vielleicht, z.B. der hier: Siemens Surpresso Compact Mikroschalter am Antrieb austauschen, Schritt 10 ?
    VauWeh - crwdns2934203:0crwdne2934203:0
  7. Siemens coffee machine Water Tank Seal Replacement, Water tank seal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Siemens coffee machine Water Tank Seal Replacement, Water tank seal: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the coffee maker so the side panel faces you.
    • Press the two plastic expansion rivets together with pliers and push them out.
    • Turn the side panel over again
    • Lift the cap over the gasket.
    • Remove the seal.
To reassemble your device, follow the steps in reverse order.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
259 328 crwdns2915208:0crwdne2915208:0
crwdns2935297:0294crwdne2935297:0
Where can I find a part-list for the seals etc? I am worried im am missing a seal. I also saw a video of usage of food grade grease I am willing to try.
Kjetil Solvang Carlsen - crwdns2934203:0crwdne2934203:0
In germany for example https://www.juraprofi.de/ or www.komtra.de. Ask them, if they ship to your country.
VauWeh -
crwdns2936753:030crwdne2936753:0 105
crwdns2942667:0crwdne2942667:0 6,256
