Siemens EQ6 Brew group overhaul
  1. Siemens EQ6 Brew group overhaul, EQ5 Brew group revision: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Siemens EQ6 Brew group overhaul, EQ5 Brew group revision: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Picture of the brewing unit. The first gasket to be replaced is on the blue water inlet.
    • This seal can be replaced immediately without further disassembly. The gasket is under strain and should be replaced quite often. It slides better when thinly coated with food-grade silicone grease.
  2. Siemens EQ6 Brew group overhaul: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The second seal, which should be replaced more often, is located on the upper piston. In theory, it could also be replaced without further disassembly. Since opening the brewing unit is not difficult, it can be cleaned more thoroughly.
  3. Siemens EQ6 Brew group overhaul: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Siemens EQ6 Brew group overhaul: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Siemens EQ6 Brew group overhaul: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the cover from the upper piston. Reach under the notches on the left and right, a plastic tool is helpful here, but you can also use your fingers. Remove the cover.
    • Now the upper piston is easily accessible from two sides and can be cleaned quite well.
  4. Siemens EQ6 Brew group overhaul: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the brewing unit on the work surface as shown.
    • Unscrew the five Torx T10 screws.
  5. Siemens EQ6 Brew group overhaul: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Siemens EQ6 Brew group overhaul: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Siemens EQ6 Brew group overhaul: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the upper side plate. The rubber bumper at the top of the piston will probably fall off. It must be pushed back into the top of the pin on the side plate during reassembly, with the smaller bumper facing down.
  6. Siemens EQ6 Brew group overhaul: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the piston completely.
    • Unscrew the Torx T10 screw on the brewing filter.
    • Take off the brewing filter.
  7. Siemens EQ6 Brew group overhaul: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Siemens EQ6 Brew group overhaul: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Siemens EQ6 Brew group overhaul: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a blunt tool, lift out the lid above the crema valve. Lift off the lid.
    • The lid is stuck very tightly. Pry it up all around with the tool to lift it up gradually.
    • Pull out the crema valve.
  8. Siemens EQ6 Brew group overhaul: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift out the cylinder with the lower piston.
    • Now the two Torx T10 screws on the blue water outlet can be removed and the water inlet can be cleaned. It is not absolutely necessary.
    • Now the brewing unit is largely disassembled. The lower piston can also be removed, but it is usually sufficient to thoroughly clean the parts that have now been removed. Replace the O-ring on the upper piston and on the water inlet (possibly on both ends), grease them and the cylinder thinly with food-grade silicone grease.
    • Reassemble everything.
    Alles bestens gelaufen, genau nach Anleitung gearbeitet, alle beweglichen Teile und Gleitschienen mit Lebensmittelsilikonfett geschmiert, Dichtungen erneuert und wieder zusammengebaut. Die Brühgruppe arbeitet wieder problemlos - sie hatte vorher übelste Geräusche von sich gegeben. Danke für die Anleitung.
    Brühgruppe der EQ6 S300
    Ford CB - crwdns2934203:0crwdne2934203:0
To reassemble your device.Work through the steps in reverse order
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
257.616 crwdns2915208:0crwdne2915208:0
crwdns2935297:0291crwdne2935297:0
Repair is War on Entropy crwdns2935289:0Repair is War on Entropycrwdne2935289:0
Community
crwdns2931471:029crwdne2931471:0
crwdns2935297:01.786crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Eine gute verständliche Anleitung mit hilfreichen Bilder. In meinem Fall hat es leider nicht geholfen, da der innenliegende Kolben, um den Kaffepuck hochzudrücken schwergängig ist. Vielleicht brauche ich eine neue Brüheinheit. Die Kaffeereste werden somit nicht ausgeworfen.
Thomas Ke - crwdns2934203:0crwdne2934203:0
@thomaske Soweit ich mich erinnere wird der untere Kolben ähnlich wie bei Saeco ausgebaut. Siehe diese Anleitung. Er ist am Kolbenschaft abgedichtet und es ist mühsam, die Dichtung zu wechseln, aber doch einen Versuch wert. Als erstes würde ich den Kolbenschaft gut fetten.
VauWeh -
Hi! In the chamber that holds to coffee grounds there is a piston that seals when pushed down and that can eject the coffee Puck when finished. Under the piston there is a seal that wears out over time. I'm having a hard time finding a replacement seal and I'm not particularly interested in buying a whole new unit only because a o-ring is getting old. Do you know what kind it is?
Joakim Jespersen - crwdns2934203:0crwdne2934203:0
@joakimjespersen If you just want the ring, you will find it here.
VauWeh -
Dear joakim,
You can buy maintenance kits on this site:
Amazon.de : siemens eq6 brüheinheit
Martin - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 85
crwdns2936753:030crwdne2936753:0 444
crwdns2942667:0crwdne2942667:0 4,903
