The XLR Connector is the part of the microphone that plugs into the cable which carries the sound to the sound mixer and speakers.
Using a small flat head screwdriver, gently turn the retaining screw at the bottom of the microphone counterclockwise until it stops or provides resistance.
Plug an XLR cable into the loose connector.
While holding the disconnect button down, pull on the cable to remove the connector from the body of the microphone.
Bend the wire around the contact point. Pin numbers are located on the outside of the connector.
Connect the red wire to Pin 3 and the blue wire to Pin 2.
Pin 1 should have a single piece of exposed wire connecting it to the metal plate on the top of the connector (the ground plate).
In one hand, hold the solder. In the other, hold your soldering iron.
Touch both the soldering iron and the solder to the contact point. The solder should melt and create a connection between the wire and the microphone connector.
Remove the solder and then the soldering iron from the contact point.
Let the wire cool for 30 seconds or so.
If the wire is not completely connected repeat steps 2 through 5.
To reinstall the XLR connector, follow the Installing Shure SM58 XLR connector guide
After soldering the wires to the XLR connector and reassembling your microphone, your microphone should be ready to plug in to the XLR cable and function properly.
crwdns2947412:09crwdne2947412:0
Many thanks. Very helpful.
Yes I'm glad it was so simple and quick to fix my mic!
Red wire to pin 3? Seems to go against the pin 2 hot method?
I'm not familiar with the "pin 2 hot method." We took a working mic apart and reassembled it the way we found it, so I'm pretty that is the correct soldering configuration.
Świetna strona. Brawo.
Son riuscito a capire meglio i colori che sul sito della Shure
Works like a charm. Thanks for the tip about the left-handed treading. My SM58 is like 100 years old and that screw worked itself loose..when I pulled the XLR out the plug came with it and broke the wires off.
To avoid this issue I will periodically check-tighten all set screws in my mics, and now I know why you are supposed to be careful when unhooking - I took for granted how tough these mics are and like 30 years later it broke.
Fully operational and a great father/daughter project afternoon thanks to this tutorial!!
Watch out those microphone pins get hot on the other end - DON’T TOUCH.
Great information! Do you know where I can get the connector with the xlr pins that goes in the bottom of the mic? I have one that is missing the bottom connector. It’s an SM58 and Shure wants like $65 to sent it in and get it swapped out but it just needs that one part, lol
How many ohm ?
Its an old microphone, I'm not the first owner. The screw keeps going infinite and not enough to the connector to come off. What can I do?
nunoandrade - crwdns2934203:0crwdne2934203:0
