Shure SM58 XLR Connector Replacement
nat coll
crwdns2944107:0crwdnd2944107:0nat collcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:06crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Yan 19, 2016crwdne2944111:0
crwdns2931287:015crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
The XLR connector is the place where the XLR cable connects to the microphone. If the connector is pulled out, the internal wiring of the microphone can be damaged.
  1. Shure SM58 XLR Connector Replacement, Connector: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shure SM58 XLR Connector Replacement, Connector: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shure SM58 XLR Connector Replacement, Connector: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While holding the microphone connector in one hand, and the XLR cable in the other hand, slowly pull them apart.
    • Make sure you are not holding the microphone connector by the wires.
    • Check to make sure all of the internal wires are connected. If you see a disconnected wire, take a look at the connector soldering guide.
  2. Shure SM58 XLR Connector Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shure SM58 XLR Connector Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the microphone connector in one hand and the microphone base in the other.
    • Line up the screw in the connector with the hole in the middle of the microphone.
    • Also, align the ridge on the microphone connector (located near the top of the connector) with the slot in the base of the microphone.
  3. Shure SM58 XLR Connector Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shure SM58 XLR Connector Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With those parts aligned, push the connector back into the microphone until the screw lines up with hole in the side of the microphone.
    • Do not push the microphone past this point or the connector may become stuck.
  4. Shure SM58 XLR Connector Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight.
    Hi looks simple but I can't undo screw turns so far and locks up. Can you help. Kind regards.
    Tony White - crwdns2934203:0crwdne2934203:0
    Are you trying to disassemble or reassemble the microphone?
    Daniel Berger - crwdns2934203:0crwdne2934203:0
    In my case, i try to disassemble.. But it wont come off. Anticlockwise the screw… infinite turns… TheThe connector is not stuck, it wabbe a bit, but the screw maybe wont recess enough.
    nunoandrade - crwdns2934203:0crwdne2934203:0
    How do I replace the screw? Lost it, and need to replace it.
    Katrina - crwdns2934203:0crwdne2934203:0
Following these steps should reinstall the XLR connector back into the microphone.
nat coll
crwdns2935283:009/27/12crwdne2935283:0
736 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-53, Forte Fall 2012 crwdns2935289:0Cal Poly, Team 7-53, Forte Fall 2012crwdne2935289:0
CPSU-FORTE-F12S7G53
crwdns2935297:030crwdne2935297:0
simple clear and precise. Small problem fixed in no time, thank you very much!
Kimmo Pekari - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 76
crwdns2942667:0crwdne2942667:0 18,265
