Are you experiencing a loss of suction? If so, an easy first step would be to check the vacuum's suction hose for any clogs, rips or separations, replace the suction hose assembly as necessary.
On the top portion of the suction hose, firmly press the tab.
Next, pull the suction hose up to detach it.
On the bottom portion of the suction hose, press the tab and pull the hose out.
Replace hose on base of shark vacume
Replace base hose on shark
Torn hose on base of shark
What if there is a tear in the hose right where he is pushing the button? How do u remove the coupling connection to fix the hose and then put back on?
How to remove hose from handle with electrical components so it can be cleaned with water? Inside of hose really needs to be cleaned
Base of vac has tear in
