Shark Rotator Powered Lift-Away Speed Belt Replacement
  1. Shark Rotator Powered Lift-Away Speed Belt Replacement, Belt: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Rotator Powered Lift-Away Speed Belt Replacement, Belt: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Rotator Powered Lift-Away Speed Belt Replacement, Belt: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the vacuum on its side.
    • Using a quarter, twist the three green locks to the unlock position.
    • Pull the bottom roller brush cover to open the vacuum.
    As a general comment. Take care and good luck with this procedure. Instructions are fine, I found just one small screw wasn't covered. Front centre in roller cavity near the centre tab. Taking apart was straightforward, then it all feels like a jelly. Bits start moving and falling off as you turn the vacuum around, spring fell off plus other bits. Eventually got it back together, but not so easy, very fiddly. Anyway it works now. MikeM
    Mike Mason - crwdns2934203:0crwdne2934203:0
  2. Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a T20 screwdriver, remove the five 15.9 mm screws on the outside cover.
  3. Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 14.3 mm screws with a T20 screwdriver.
    there is also a small ~13mm PH0 screw on the center of the edge in front of the roller between the 2 other screws indicated that must be removed before you can get the cover off.
    Jack Robertson - crwdns2934203:0crwdne2934203:0
  4. Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 14.3 mm screws under the wheels with a T20 screwdriver bit.
  5. Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 15.9 mm screws from behind the wheels with a T20 bit screwdriver.
  6. Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 13.4 mm small screw behind the roller brush with a PH0 screwdriver bit.
  7. Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 13.4 mm screw from behind the belted end of the roller brush with a T20 screwdriver bit.
  8. Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the vacuum around.
    • Using a spudger, pry the top of the vacuum cover off. There are three tabs behind each of the clear rectangles below the headlights.
  9. Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove both of the headlight covers with the spudger.
  10. Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the grey side panel on the motor side of the vaccum with a spudger. Pry under each tab to release the side panel.
  11. Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 13.4 mm screws with a T20 bit screwdriver.
  12. Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 13.4 mm screw located next to where the belt was detached, securing the motor in place, with a PH1 screwdriver.
  13. Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the visible side of the belt from the gear with a spudger.
  14. Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the grey panel from the opposite side, by uncrewing the single 13.4 mm screw with a PH1 screwdriver. This will release the container for the roller brush and belt motor.
  15. Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, push the white end cap out of the clear plastic by placing the spudger on the roller brush side and pushing the cap outward.
  16. Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Rotator Powered Lift-Away Speed Belt Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the belt from the gear.
    Thank you for posting this. I couldnt find these instructions anywhere else.
    Having questions1966 - crwdns2934203:0crwdne2934203:0
Dakota Rodriguez-Ransom
crwdns2935283:010/08/18crwdne2935283:0
623 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S4-G6, White Fall 2018 crwdns2935289:0Cal Poly, Team S4-G6, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S4G6
Where can we buy belts in UK?
Greg Norman - crwdns2934203:0crwdne2934203:0
where cn i get a belt for this vaccum
Annie Pappineau - crwdns2934203:0crwdne2934203:0
We have the belts courtesy of that place named after a rainforest. This morning I took out enough screws to weigh them in and take a holiday with the reward, couldn't see how to get in so gave up in frustration and replaced all the screws. The usual Google search provides images of the side cover removal via screws but for some reason ours doesn't have any side access. I found this post eventually so will be trying again later when the old blood pressure has returned to acceptable levels. Jeez, that's a lot screws just for a new belt. We love the Shark after years of Dysons, but comparing ease of home servicing leaves a lot to be desired..
Barrie Harnett - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 27
crwdns2936753:07crwdne2936753:0 140
crwdns2936753:030crwdne2936753:0 568
crwdns2942667:0crwdne2942667:0 46,854
