Shark Professional Steam Pocket Mop Steam Nozzle Replacement
  1. Shark Professional Steam Pocket Mop Steam Nozzle Replacement, Steam Nozzle: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the mop head release button to remove it from the steam mop body.
  2. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 10mm screws holding the joint assembly to the mop head with your Phillips #2 screwdriver.
  3. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two plastic hinge covers by pulling the hinges out of the joint and sliding the covers off.
  4. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Stretch joint assembly forward to expose two 11mm Phillips #2 screws on either side of the steam tube.
    • Remove both screws.
  5. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift joint assembly out of hinge socket and pull upward with mild force to disconnect steam nozzle.
  6. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use needle nose pliers to compress metal clamp .
  7. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the nozzle out of the tube.
    Where can I get a new rubber hose? The one I have broke in half.
    Akiva Israel - crwdns2934203:0crwdne2934203:0
Michael Raymond
crwdns2935283:002/12/18crwdne2935283:0
154 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S15-G1, Boczar Spring 2018 crwdns2935289:0USF Tampa, Team S15-G1, Boczar Spring 2018crwdne2935289:0
USFT-BOCZAR-S18S15G1
This was fantastic. Only place I found on how to disassemble mop head. If i were you, I would go a little further and explain how to clean the nozzle. Use a paper clip or 20 gauge wire to push build up out. If that does not work use a small drill bit ( be careful to drill straight or you could damage the wall or jacket . This worked for me. Saved me $30. Had a problem locating this sight. Maybe some way to make it easier to locate would help. Thanks for your posting.
Mike Cunningham - crwdns2934203:0crwdne2934203:0
Do you know if I can soak this part in clr? I can't seem to clean it well enough.
Kelsey Harper -
crwdns2936753:030crwdne2936753:0 133
crwdns2942667:0crwdne2942667:0 5,577
