Shark Professional Steam Pocket Mop Heating Element Replacement
  1. Shark Professional Steam Pocket Mop Heating Element Replacement, Shark Professional Steam Pocket Mop Front Panel Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Professional Steam Pocket Mop Heating Element Replacement, Shark Professional Steam Pocket Mop Front Panel Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unwrap the power cord from the handle.
    • Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
    • Pull the handle to separate it from the body.
  2. Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 12.0 mm Phillips head #2 screws where the handle connects to the body.
    • Remove the plastic cap.
  3. Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 16.0 mm T10 Torx screws near the top of the body and remove the water tank cap.
    • The third screw is directly on other side of the bottom screw in the photo.
  4. Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove steam control button cover with a metal spudger.
    • Remove the two 12.0 mm Phillips head #2 screws underneath.
    • Remove the plastic rim with clear plastic cover.
    Don’t remove the whole cover!!! Only remove the label! I now have three broken screws and a steam mop that is junk! Please be more clear!!!
    Martha m - crwdns2934203:0crwdne2934203:0
  5. Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the Shark logo decal on the front of body using a metal spudger.
    • Pull out the plastic cover to remove.
  6. Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pop off the grey front plate to expose the control panel and screws necessary to open mop body.
  7. Shark Professional Steam Pocket Mop Heating Element Replacement, Shark Professional Steam Pocket Mop Open Mop Body: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 12.0 mm Philips head #2 screws connected to the dark grey plastic trim.
  8. Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 16.0 mm T10 Torx screws located on the back of the mop.
  9. Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 12.0 mm Phillips head #2 screws that hold the power cord to the device.
  10. Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pop off the dark grey plastic trim cover.
  11. Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pop open the white plastic mop body by pulling apart from the front and back side.
  12. Shark Professional Steam Pocket Mop Heating Element Replacement, Heating Element: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 12.0 mm Phillips head #2 screws on the sides of the heating element.
  13. Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the heating element and use precision tweezers or pliers to pinch and loosen the two clamps.
    • Remove both tubes from the heating element.
  14. Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip each wire at its base and pull to disconnect them from the heating element.
  15. Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 12.0 mm Phillips head #2 screws from the heating element.
  16. Shark Professional Steam Pocket Mop Heating Element Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull apart wire connectors to fully detach the heating element.
    Do you replace the element or are you saying once you detach you go ahead and reattach the same element
    Sandra R Pannell - crwdns2934203:0crwdne2934203:0
Brett Wilson
crwdns2935283:002/12/18crwdne2935283:0
1.019 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S15-G1, Boczar Spring 2018 crwdns2935289:0USF Tampa, Team S15-G1, Boczar Spring 2018crwdne2935289:0
USFT-BOCZAR-S18S15G1
crwdns2947412:08crwdne2947412:0
Is the heating element available somewhere? I cannot find it anywhere.
Mark Cashion - crwdns2934203:0crwdne2934203:0
Where can the heating element be purchased in order to replace? Can’t find anywhere.
Amanda Krusenstjerna - crwdns2934203:0crwdne2934203:0
i have a shark s3973d. and i need a heating elementand the two hosese connected
to the heating element. if no heating element. would like to order the hoses.
RICHARD MARTINEZ - crwdns2934203:0crwdne2934203:0
Once element is detached where do I get a new one
I just bought this shark steam vac less than 6months ago
How do you get the wires off without the metal breaking
Content - - crwdns2934203:0crwdne2934203:0
Thank you. I took it apart. Took heating element apart. Soaked it in white vinegar overnight.
Works like new. Mine had security #10 torex screws which were difficult to remove, but I got them out
Albert Colian - crwdns2934203:0crwdne2934203:0
PLEASE tell us how/ where to get replacement heating element.
THANK YOU
Patricia Barry - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 36
crwdns2936753:030crwdne2936753:0 157
crwdns2942667:0crwdne2942667:0 7,262
