Shark Pet Perfect II Battery Replacement
crwdns2942287:0crwdne2942287:0This step by step guide will help you remove the battery from its compartment. The battery can be easily removed in 4 steps, with very few tools. Care should be used when handling the battery.
crwdns2944105:0crwdne2944105:0
Locate and remove the 7.5mm Philips screw holding the battery cover in place on bottom of the vacuum.
Once the cover is removed, slide the plastic retaining bracket down and pull out to remove.
Pull the battery out of the compartment.
Carefully disconnect the quick disconnect couplers.
Completely remove the old battery from the vacuum .
crwdns2935103:0crwdne2935103:0
crwdns2947412:012crwdne2947412:0
Removed the single screw but cover will not come off. What do you do?
Just tried it. The cover is a bit hard. Gold the vacuum at an angle and slightly push the notch on the cover with a flat screwdriver, it should come out.
Will it run on cord only
NO. Requires batteries.
1.) Mine was much harder to disassemble, took considerable force.
2.) No one sells form, fit and function replacement batteries, including Shark
3.) The available replacement are much smaller in volume, and hence power, and require padding or they will rattle.
Where do I get a replacement battery for it?
Model SV780N1 14. Original batteries were three sets of battery packs daisy-chained together and tucked into the housing. The nylon band around the larger pack had deteriorated and came apart when attempting to pull it out. So, loosened the housing screws enough to slightly open up the housing and was able to pry out.
Where are replacement batteries sold
Where are replacement batteries sold ?
I bought my replacement battery from Amazon.
Thank you!! This is exactly what I needed and it worked!!
My model, SV780 N1 14, takes the daisy chained batteries, XBT779. These batteries cost more than buying a new model. Is there a similar battery that doesn't cost as much that will work?
Why do these cost so much? Are batteries in the newer models better now, and maybe I should just get a newer model?
