Shark Navigator Freestyle SV1106 Roller Belt Replacement
  1. Shark Navigator Freestyle SV1106 Roller Belt Replacement, Battery Pack: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device over to reveal the bottom of the motorized brush head.
  2. Shark Navigator Freestyle SV1106 Roller Belt Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Navigator Freestyle SV1106 Roller Belt Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the latch next to the panel upwards into the unlocked position.
  3. Shark Navigator Freestyle SV1106 Roller Belt Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the panel to the right to reveal the battery.
  4. Shark Navigator Freestyle SV1106 Roller Belt Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Navigator Freestyle SV1106 Roller Belt Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the battery from the vacuum.
  5. Shark Navigator Freestyle SV1106 Roller Belt Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Navigator Freestyle SV1106 Roller Belt Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery from the vacuum by pinching the white latch and pulling the two pieces apart.
  6. Shark Navigator Freestyle SV1106 Roller Belt Replacement, Roller Belt: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Navigator Freestyle SV1106 Roller Belt Replacement, Roller Belt: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Navigator Freestyle SV1106 Roller Belt Replacement, Roller Belt: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the eight 25.4 mm Phillips #1 screws holding the bottom panel to the vacuum.
    • Use the metal spudger to remove the plastic plug to reveal a 12.4 mm Phillips #1 screw and remove it.
  7. Shark Navigator Freestyle SV1106 Roller Belt Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the final 25.4 mm Phillips #1 screw inside the battery compartment.
  8. Shark Navigator Freestyle SV1106 Roller Belt Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Navigator Freestyle SV1106 Roller Belt Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Navigator Freestyle SV1106 Roller Belt Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the bottom panel from the vacuum by pressing to release the latches at the front and pulling the bottom panel away from the vacuum.
    There was a spring that popped out at this step and can’t figure out how or where it goes too??
    Tried putting it in the foot switch and reinstalled vacuum but switch didn’t work?
    G G - crwdns2934203:0crwdne2934203:0
    Same thing happened to still have spring and assembled leaving it out and motor will not start
    Ed Hungness - crwdns2934203:0crwdne2934203:0
    Ok, finally fixed. Putting the little spring back is key. Suggestion: the lay the white top upside down on table, drop spring into tube where it goes then reassemble in upside down position so spring doesn’t fall putting vacuum back together,
    Ed Hungness -
  9. Shark Navigator Freestyle SV1106 Roller Belt Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Navigator Freestyle SV1106 Roller Belt Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Navigator Freestyle SV1106 Roller Belt Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 12.2 mm Phillips #1 screws holding the motor in place and remove the motor by pulling directly upwards.
  10. Shark Navigator Freestyle SV1106 Roller Belt Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Navigator Freestyle SV1106 Roller Belt Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the belt by sliding it off the end of the motor.
    are you &&^&^$^ kidding?????????????????
    i'm 85 will never buy a shark product again
    Jeri Piotrowski - crwdns2934203:0crwdne2934203:0
    Solution, go buy a new vac!🤓
Zachary Liu
crwdns2935283:001/24/18crwdne2935283:0
604 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G5, Livingston Winter 2018 crwdns2935289:0Cal Poly, Team S1-G5, Livingston Winter 2018crwdne2935289:0
CPSU-LIVINGSTON-W18S1G5
crwdns2947412:020crwdne2947412:0
Where can I purchase the belt. It is a “Pioneer Rubber Belt 148 2m”.
Please contact me.
Thank you.
itsagas03@hotmail.com
itsagas03 - crwdns2934203:0crwdne2934203:0
Try amazon…replacement belt for shark navigator freestyle cordless vacuum
Cathy Martin -
I got the belt from http://shop.polybelt.com/ It is item B148-2M-04BNG . You have to buy 3 to get to $9.99 and then they tack on another $10 for shipping, but this was the only place I could find them. Replaced it and it seems to be working ok.
rmagnus - crwdns2934203:0crwdne2934203:0
The brush stops tolling after a few seconds. How do I trouble shoot this?
Peter Fogler - crwdns2934203:0crwdne2934203:0
Same happens to me. I took it all apart; there was not much hair in the mechanisms at all, and the belt is not broken so I don't see the need to replace it. I am at a loss as to what I should do next.
Esther Odneal -
Same problem for me. Not a happy camper after spending money and time to have the same problem.
bohlke_ks -
Hi Pete, I found by removing the roller brush, you will be able to remove accumulated hair strands around the brush and related bearings. Having problems finding the 2mm x 148 belt. however it looks like “rmagnus” hit pay dirt through shop.polybelt.com. I’ll give that a shot.
Good luck.
Steve Lundgren - crwdns2934203:0crwdne2934203:0
I wish you could mention the spring…
Diane Yoder - crwdns2934203:0crwdne2934203:0
The spring goes in the long screw hole in the top cover.
Esther Odneal -
Google search of model # reveals several sources for belts. Most from China requiring 4 week wait.
Alice Kenyon - crwdns2934203:0crwdne2934203:0
I followed the instructions (which are great) and got it apart and replaced the belt. Put it back together and it will not turn on. Been charging for awhile. Is there something I did wrong when I put it back together?
Deborah Doan - crwdns2934203:0crwdne2934203:0
The brush stops rolling after a few seconds. I took it all apart; there was not much hair in the mechanism at all, and the belt is not broken so I don't see the need to replace it. I am at a loss as to what I should do next? Any advice, please?
Esther Odneal - crwdns2934203:0crwdne2934203:0
My 14.4 version of the freestyle will not run if the upper assembly is attached. When turned on the roller motor runs for 2 seconds and then shuts off. Is the Suction motor in the handle dead? There are no clogs or tangles. Again…when the handle is detached the brush motor runs.but shuts of in 2 seconds. The suction motor does not start.
Kern Thompson - crwdns2934203:0crwdne2934203:0
I wish you had mentioned the spring, I didn’t see where it came from.
smoore532000 - crwdns2934203:0crwdne2934203:0
I need the part that is above the belt on left side.
Nicole - crwdns2934203:0crwdne2934203:0
Hello:
I just replaced the belt today in this vacuum, this tutorial was awesome & helpful. When putting it all back together a spring fell out and I have no idea where it might go, so I thought I’d inquire and see if you can provide any insight. It’s 1 3/4 in. long and resembles a spring you would find in a pen, but it’s smaller in diameter. Any help would be much appreciated.
Shannon Quinlan - crwdns2934203:0crwdne2934203:0
Follow up to previous post…deductive reasoning told me that spring likely went into the hole connected to the on/off button. It fit in the hole so that’s were I left it! I put it all back together…and it low and behold started!! So I hope my guess was correct…if it wasn’t, oh well…it worked!! Haha!!
I too replaced the belt, and tolling is not happening… anyone have answers?
bohlke_ks - crwdns2934203:0crwdne2934203:0
The belt may not be broken but warn down so it slips and doesn’t turn the brush. You can buy them on Amazon in packs of 2
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 6,706
