Shark ION Robot 750 Main Wheel Assembly Replacement
  1. Shark ION Robot 750 Main Wheel Assembly Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION Robot 750 Main Wheel Assembly Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION Robot 750 Main Wheel Assembly Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the device is completely powered off before working.
    • Flip over the vacuum on a flat and uncluttered service with the bottom facing upwards.
    • Remove all seven 9.1mm Torx T15 screws from the device’s front bumper.
    • Remove the nine 9.1mm Torx T6 bolts from outer shell.
  2. Shark ION Robot 750 Main Wheel Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark ION Robot 750 Main Wheel Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slightly pull front bumper to expose internal wiring.
    • Unplug the device’s front bumper wiring and completely remove front bumper.
  3. Shark ION Robot 750 Main Wheel Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark ION Robot 750 Main Wheel Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 9.5mm Torx T6 bolts on the yellow brush frame.
    • Gently depress the two tabs on the frame, then lift the frame to remove it.
  4. Shark ION Robot 750 Main Wheel Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark ION Robot 750 Main Wheel Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pick up the brush and remove it from the vacuum.
    • Push the brush to your right and lift it.
  5. Shark ION Robot 750 Main Wheel Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION Robot 750 Main Wheel Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION Robot 750 Main Wheel Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press and hold the dust bin removal button to slide out the dust bin.
  6. Shark ION Robot 750 Main Wheel Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the outer shell to expose the Shark’s interior.
  7. Shark ION Robot 750 Main Wheel Assembly Replacement, Main Wheel Assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark ION Robot 750 Main Wheel Assembly Replacement, Main Wheel Assembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect each of the cable connectors attached to the motherboard to free the wheel assembly from the vacuum for both the left and right wheels.
    • For helpful details on disconnecting different types of connectors, check out the Recognizing and Disconnecting Cable Connectors guide.
  8. Shark ION Robot 750 Main Wheel Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION Robot 750 Main Wheel Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION Robot 750 Main Wheel Assembly Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger or your fingers to detach all of the cables from the connectors on the motherboard that connect to the wheels.
    • This guide demonstrates the right wheel removal but you can use this guide to remove the left wheel assembly as well.
    • Unhook the remaining wires that are connected to the back of the wheel.
    • Do not rip the wires when removing them from the wheel and motherboard.
  9. Shark ION Robot 750 Main Wheel Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION Robot 750 Main Wheel Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION Robot 750 Main Wheel Assembly Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the three 12 mm screws that hold the right wheel in place.
    • Be careful not to strip the screws when removing them from the wheel. Take a look at this guide for Screwdriver Best Practices.
    • Remove the right wheel assembly from the socket.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Talia Marquez
crwdns2935283:002/08/24crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 1-7, Coppersmith Spring 2024 crwdns2935289:0University of North Texas, Team 1-7, Coppersmith Spring 2024crwdne2935289:0
UNT-COPPERSMITH-S24S1G7
crwdns2942667:0crwdne2942667:0 263
