Sennheiser Momentum 4 Left Driver Assembly Replacement
  1. Sennheiser Momentum 4 Left Driver Assembly Replacement, Ear Pads: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sennheiser Momentum 4 Left Driver Assembly Replacement, Ear Pads: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a spudger into the seam between the left ear pad and driver assembly.
    • Gently pry around the perimeter of the ear pad until it fully releases.
    • Remove the left ear pad.
    • Repeat for the right ear pad if necessary.
  2. Sennheiser Momentum 4 Left Driver Assembly Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sennheiser Momentum 4 Left Driver Assembly Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four 6.5 mm screws that secure the left driver housing.
  3. Sennheiser Momentum 4 Left Driver Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the flat end of a spudger into the driver housing seam.
    • Gently pry the driver housing up and out, with care not to strain or damage the connected cables.
  4. Sennheiser Momentum 4 Left Driver Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift away the driver housing out and flip it over to reveal the battery cover.
    • Use tweezers to pull the white battery connector directly out of the daughterboard socket.
    • It disconnects similarly to removing a plug from a socket.
  5. Sennheiser Momentum 4 Left Driver Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of a spudger to pry open the retaining clips on the battery cover and remove it carefully.
  6. Sennheiser Momentum 4 Left Driver Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sennheiser Momentum 4 Left Driver Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger between the lower edge of the battery and the battery housing.
    • Do not bend, warp, or puncture the battery.
    • Gently lift the battery upward to release the adhesive that secures the battery.
    • If necessary, use a hairdryer to lightly heat the battery to loosen the adhesive.
    • Remove the battery.
  7. Sennheiser Momentum 4 Left Driver Assembly Replacement, Left Driver Assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the two driver assembly motherboard connections.
    • Remove the driver assembly.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Connor
crwdns2935283:003/29/22crwdne2935283:0
15.198 crwdns2915208:0crwdne2915208:0
crwdns2935297:074crwdne2935297:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 50
crwdns2942667:0crwdne2942667:0 50
