Sennheiser Momentum 4 Battery Replacement
  1. Sennheiser Momentum 4 Battery Replacement, Ear Pads: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sennheiser Momentum 4 Battery Replacement, Ear Pads: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a spudger into the seam between the left ear pad and driver assembly.
    • Gently pry around the perimeter of the ear pad until it fully releases.
    • Remove the left ear pad.
    • Repeat for the right ear pad if necessary.
  2. Sennheiser Momentum 4 Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sennheiser Momentum 4 Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four 6.5 mm screws that secure the left driver housing.
  3. Sennheiser Momentum 4 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the flat end of a spudger into the driver housing seam.
    • Gently pry the driver housing up and out, with care not to strain or damage the connected cables.
  4. Sennheiser Momentum 4 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift away the driver housing out and flip it over to reveal the battery cover.
    • Use tweezers to pull the white battery connector directly out of the daughterboard socket.
    • It disconnects similarly to removing a plug from a socket.
  5. Sennheiser Momentum 4 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of a spudger to pry open the retaining clips on the battery cover and remove it carefully.
  6. Sennheiser Momentum 4 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sennheiser Momentum 4 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger between the lower edge of the battery and the battery housing.
    • Do not bend, warp, or puncture the battery.
    • Gently lift the battery upward to release the adhesive that secures the battery.
    • If necessary, use a hairdryer to lightly heat the battery to loosen the adhesive.
    • Remove the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Madolyn Mueske
crwdns2935283:001/23/25crwdne2935283:0
797 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-4, Virtue Spring 2025 crwdns2935289:0Western Carolina University, Team 1-4, Virtue Spring 2025crwdne2935289:0
WCU-VIRTUE-S25S1G4
crwdns2936751:024crwdne2936751:0 50
crwdns2936753:07crwdne2936753:0 224
crwdns2936753:030crwdne2936753:0 930
crwdns2942667:0crwdne2942667:0 2,514
