Sennheiser HD 4.50 Volume Control Button Replacement
crwdns2942287:0crwdne2942287:0This is a repair guide for the Volume Control function of the Sennheiser HD 4.50 Bluetooth headphones. If users are having issues with changing the volume then this guide could be helpful. Make sure first of all that you’ve attempted to turn up the volume all the way. If you are still having trouble, your volume control function may not be working properly. Use this guide to help.
If your volume control buttons are sticky or stuck, this guide will help you to replace the button. If the button still moves properly, but doesn’t have any response to input, you may need to address the problem by replacing the volume control board instead.
crwdns2944105:0crwdne2944105:0
Locate the side designation on the headband-earpiece junction.
Remove the right side ear pad.
Use the Phillips #00 screwdriver to remove the four 10 mm screws holding the ear cup cover in place.
Use an opening tool to pry off the cover.
Use a Phillips #000 screwdriver to remove the four 6 mm screws holding the motherboard in place.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to remove the hot glue that covers the wires
Using the tweezers, grasp and slowly pull away the wires from the motherboard until they disconnect.
Use the iFixit opening tools to lift up on the motherboard.
While lifting up with the tool, grab and pull the motherboard with your free hand away from the button functions until it disconnects.
Desolder the three wires that are on the underside of the motherboard now that it is free.
Remove the motherboard.
Use a pair of tweezers to push the outer portion of the volume control button through the opening.
Using the tweezers, grasp the portion of the volume control button that is connected to the inside of the ear cup. Pull away until the button disconnects.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:03crwdne2947412:0
Thank you! This helped me open my pair of headphones, and I was able to fix an intermittent connection to the headphone jack (by reheating the pads).
I should add that the diffuser for the LED should be pulled off by user before trying to lift up the board, as it will not come off out of it's hole by itself and it does block the board from being lifted.
Nice explanation thank you
