Scuf Reflex Thumbsticks Replacement
  1. Scuf Reflex Thumbsticks Replacement, Pry up the right faceplate trim edge: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Scuf Reflex Thumbsticks Replacement, Pry up the right faceplate trim edge: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Scuf Reflex Thumbsticks Replacement, Pry up the right faceplate trim edge: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The faceplate trim is secured by plastic clips.
    • At the bottom tip of the right grip, insert the flat end of a spudger or a clean fingernail between the faceplate trim and the back cover.
    • Pry up to release the faceplate trim’s bottom right clip.
  2. Scuf Reflex Thumbsticks Replacement, Pry up the left faceplate trim edge: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Scuf Reflex Thumbsticks Replacement, Pry up the left faceplate trim edge: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Scuf Reflex Thumbsticks Replacement, Pry up the left faceplate trim edge: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • At the bottom tip of the left grip, insert the flat end of a spudger or a clean fingernail between the faceplate trim and the back cover.
    • Pry up to release the faceplate trim’s bottom left clip.
  3. Scuf Reflex Thumbsticks Replacement, Pry up the center of the faceplate trim: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Scuf Reflex Thumbsticks Replacement, Pry up the center of the faceplate trim: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger between the faceplate trim and the back cover, next to the headphone jack.
    • Pry up to release the plastic clips securing the center of the faceplate trim.
  4. Scuf Reflex Thumbsticks Replacement, Remove the faceplate trim: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Scuf Reflex Thumbsticks Replacement, Remove the faceplate trim: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Scuf Reflex Thumbsticks Replacement, Remove the faceplate trim: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The top corners of the faceplate trim are slotted up underneath the faceplate.
    • Lift the bottom edge of the faceplate trim and thread it up and over the thumbsticks.
    • Pull the top corners of the faceplate trim out from underneath the faceplate and remove the faceplate trim.
    • To reinstall the faceplate trim, slide its top corners under the faceplate and over the thumbsticks, then push down along the edges of the trim to engage the clips securing it.
  5. Scuf Reflex Thumbsticks Replacement, Remove the thumbsticks: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Scuf Reflex Thumbsticks Replacement, Remove the thumbsticks: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Scuf Reflex Thumbsticks Replacement, Remove the thumbsticks: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the thumbsticks straight up and off of their joysticks to remove them.
    • To reinstall the thumbsticks, place them in their original position and push down until they lock in place.
To reassemble your device, follow the instructions in reverse order.
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
235 943 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 151crwdne2935297:0
Actually, the base of the thumbsticks is bigger and you can't pull it up. I really don't know if the new models are different.
I had to release the entire top cover.
Igor Minoru - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 22
crwdns2936753:07crwdne2936753:0 100
crwdns2936753:030crwdne2936753:0 363
crwdns2942667:0crwdne2942667:0 4,374
