Screen Assembly Removal
  1. Screen Assembly Removal, Turn off the watch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Screen Assembly Removal, Turn off the watch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Screen Assembly Removal, Remove the rear screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Screen Assembly Removal, Separate the back cover from the housing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Screen Assembly Removal, Separate the back cover from the housing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Screen Assembly Removal, Separate the back cover from the housing: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Screen Assembly Removal, Disconnect the sensor array: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Screen Assembly Removal, Disconnect the sensor array: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Screen Assembly Removal, Remove the back cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover.
  6. Screen Assembly Removal, Disconnect the display and the mic array: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Screen Assembly Removal, Disconnect the display and the mic array: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Screen Assembly Removal, Disconnect the display and the mic array: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to disconnect the display assembly and the microphone and pressure sensor array.
  7. Screen Assembly Removal, Undo the mic tape: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Screen Assembly Removal, Undo the mic tape: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Screen Assembly Removal, Undo the mic tape: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening pick to peel back the thin tape belonging to the microphone array.
    • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
  8. Screen Assembly Removal, Lift the core assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Screen Assembly Removal, Lift the core assembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick at the bottom right between the motherboard and the frame to lift up the core assembly.
  9. Screen Assembly Removal, Remove the core assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Screen Assembly Removal, Remove the core assembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Screen Assembly Removal, Remove the core assembly: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift out and remove the core assembly.
  10. Screen Assembly Removal, Loosen the mic: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Screen Assembly Removal, Loosen the mic: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to loosen the microphone which is fixed to the frame with mild adhesive.
  11. Screen Assembly Removal, Free the barometric sensor: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Screen Assembly Removal, Free the barometric sensor: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to lift the pressure sensor up and out of its recess in the frame.
  12. Screen Assembly Removal, Remove the mic array: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the microphone and barometric sensor array from the frame.
Tobias Isakeit
crwdns2935283:003/31/14crwdne2935283:0
134,046 crwdns2915208:0crwdne2915208:0
crwdns2935297:0189crwdne2935297:0
Tobias Isakeit - Repairability Engineer crwdns2935289:0Tobias Isakeit - Repairability Engineercrwdne2935289:0
Business
crwdns2935297:01,151crwdne2935297:0
crwdns2936753:030crwdne2936753:0 55
crwdns2942667:0crwdne2942667:0 925
