Is your flash not working anymore? This guide will show you how to replace the entire flash assembly and light up your pictures.
Remove the 7 screws on the outside of the camera
Two 5 mm PH000 screws on the right side of the camera body
Four 3mm PH000 screws on the bottom and the left side of the camera body.
Use the plastic spudger to push the back casing out. Start from the right side and work your way clockwise around the case.
Disconnect the set of wires from the back casing to the motherboard. Do this by using the plastic spudger to flip the black tab up and the wires will pull out.
Unscrew the four 3 mm and two silver 1 mm PH000 screw from the green motherboard.
Unscrew the two 3 mm screws from the top cover with the PH000 driver.
Along with the one 2 mm screw, also a PH000 screw.
Use the spudger and pry the top cover off starting on the left side and working your way down.
After the top is disconnected, fold it back so the two PH000 flash screws are accessible and remove the cover.
Remove the flash bulb from the red housing and clear cover. Do this by pushing back the flash bulb back out of the red housing.
Desolder the wires from the circuit board. Learn more about soldering here.
Hola, mi camara wb2100 se queda colgada y los comandos responden pasados varios segundos y al iniciar arranca con valores por defecto, es decir que no graba las configuraciones luego que se apaga, es muy molesto usarla de esta forma y quisiera saber si hay forma de resetearla para ver si se soluciona el problema. Alguien tiene idea de como resetear esta cámara? se agradece vuestra ayuda.
