Samsung UBD-KM85C Disc Drive Replacement
  1. Samsung UBD-KM85C Disc Drive Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
  2. Samsung UBD-KM85C Disc Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung UBD-KM85C Disc Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front.
  3. Samsung UBD-KM85C Disc Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung UBD-KM85C Disc Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung UBD-KM85C Disc Drive Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it.
  4. Samsung UBD-KM85C Disc Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cover from the device.
  5. Samsung UBD-KM85C Disc Drive Replacement, Disc Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The disk drive is the large metallic rectangular unit that occupies a third of the space inside the unit.
  6. Samsung UBD-KM85C Disc Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung UBD-KM85C Disc Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The disk drive has four 6.5mm screws located near each of its corners that hold it onto the frame. Use a #1 Phillips head screwdriver to remove these screws.
  7. Samsung UBD-KM85C Disc Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung UBD-KM85C Disc Drive Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung UBD-KM85C Disc Drive Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The disk drive has two connections to the motherboard that can be disconnected by pulling on the blue plastic tabs.
  8. Samsung UBD-KM85C Disc Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the connections are unplugged and the screws are removed, the disk drive can be lifted out. The previous steps can be done in the reverse order to replace the part.
James Edwards
crwdns2935283:002/01/18crwdne2935283:0
627 crwdns2915208:0crwdne2915208:0
Baylor, Team S2-G1, Johnson Spring 2018 crwdns2935289:0Baylor, Team S2-G1, Johnson Spring 2018crwdne2935289:0
BU-JOHNSON-S18S2G1
How do I eject a disk that's stuck in the drive?
Martin Y - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 445
