Samsung Series 5 Ultrabook Speakers Replacement
  1. Samsung Series 5 Ultrabook Speakers Replacement, Remove the Screws on the Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Series 5 Ultrabook Speakers Replacement, Remove the Screws on the Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
    The user manual recommends, before removing the cover:
    "Insert an object, such as a paper clip, into the Emergency Hole at the bottom of the computer to cut the battery power. If the Power button does not work anymore, that means you successfully shut the power off."
    This seems to make sure power is completely off or something. The hole can be seen in the picture; it is located in the center, very near where the screwdriver is.
    Pachi - crwdns2934203:0crwdne2934203:0
  2. Samsung Series 5 Ultrabook Speakers Replacement, Remove the Rubber Pads: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Series 5 Ultrabook Speakers Replacement, Remove the Rubber Pads: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. Samsung Series 5 Ultrabook Speakers Replacement, Remove the Back Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Series 5 Ultrabook Speakers Replacement, Remove the Back Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Samsung Series 5 Ultrabook Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Series 5 Ultrabook Speakers Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tape holding the wires in place.
  5. Samsung Series 5 Ultrabook Speakers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Samsung Series 5 Ultrabook Speakers Replacement, Remove the Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery connector towards the battery to disconnect it.
  7. Samsung Series 5 Ultrabook Speakers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the laptop.
Javier Jimenez
crwdns2935283:011/04/19crwdne2935283:0
223 crwdns2915208:0crwdne2915208:0
IUPUI, Team S1-G6, Harley Fall 2019 crwdns2935289:0IUPUI, Team S1-G6, Harley Fall 2019crwdne2935289:0
IUPUI-HARLEY-F19S1G6
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 835
