Samsung SGH-E317 Camera Replacement
  1. Samsung SGH-E317 Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back panel by pressing up on switch, located at the top on the back of the phone.
    • You may want to use a plastic opening tool to help pry the back panel off.
  2. Samsung SGH-E317 Camera Replacement, Motherboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four 4.5mm screws located on the back plate.
  3. Samsung SGH-E317 Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber screw cover using your fingernail.
  4. Samsung SGH-E317 Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 4.5mm screw located underneath the rubber cover.
  5. Samsung SGH-E317 Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
    • The panel should come off without much effort.
  6. Samsung SGH-E317 Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the back panel removed, the motherboard should be fully exposed.
  7. Samsung SGH-E317 Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung SGH-E317 Camera Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the camera and volume buttons and place them in a safe spot until reassembly.
  8. Samsung SGH-E317 Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung SGH-E317 Camera Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
  9. Samsung SGH-E317 Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung SGH-E317 Camera Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
  10. Samsung SGH-E317 Camera Replacement, Camera: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung SGH-E317 Camera Replacement, Camera: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to remove the plastic screw coverings at the base of the LCD screen.
  11. Samsung SGH-E317 Camera Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the screwdriver to remove the two 4.5mm screws located underneath the plastic coverings.
    • You may want to use tweezers to remove the loosened screws.
  12. Samsung SGH-E317 Camera Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge the plastic opening tool under the crevice on the inner surface of the phone screen.
    • Gently pry the top panel off around the entire frame.
  13. Samsung SGH-E317 Camera Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung SGH-E317 Camera Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure that the top panel is completely separated from the LCD display around the entire perimeter.
  14. Samsung SGH-E317 Camera Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the top panel off of the phone.
  15. Samsung SGH-E317 Camera Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung SGH-E317 Camera Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the wedge to detach the connecting wire panel from the LCD display system.
    • Be gentle when detatching this wire to prevent damaging surrounding components.
  16. Samsung SGH-E317 Camera Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung SGH-E317 Camera Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tweezers to remove the camera from the cellphone casing.
To reassemble your device, follow these instructions in reverse order.Take your e-waste to an R2 or e-Stewards certified recycler.
Michael Strange
crwdns2935283:001/30/11crwdne2935283:0
Cal Poly, Team 11-23, Maness Winter 2011 crwdns2935289:0Cal Poly, Team 11-23, Maness Winter 2011crwdne2935289:0
CPSU-MANESS-W11S11G23
crwdns2942667:0crwdne2942667:0 1,628
