Samsung S760 Battery Cover Replacement Guide
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Samsung S760 Battery Cover  Replacement Guide, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung S760 Battery Cover  Replacement Guide, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung S760 Battery Cover  Replacement Guide, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Placing your thumb on the battery cover, push outwards, away from the camera in the direction the arrow is pointing. If done correctly when it's completely unhooked, the latch will open.
  2. Samsung S760 Battery Cover  Replacement Guide: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung S760 Battery Cover  Replacement Guide: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tip the camera as to gently slide the batteries out of the camera.
  3. Samsung S760 Battery Cover  Replacement Guide, Front and Back Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung S760 Battery Cover  Replacement Guide, Front and Back Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung S760 Battery Cover  Replacement Guide, Front and Back Case: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • All screws in this camera are removed using the Phillip Screwdriver #000 bit. Also, all dimensions included refer to screw lengths.
    • Locate and remove the six 4mm screws on the sides of the camera.
  4. Samsung S760 Battery Cover  Replacement Guide: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung S760 Battery Cover  Replacement Guide: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to pry open the back case, following alongside the edge of the case if need be.
  5. Samsung S760 Battery Cover  Replacement Guide: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the back case is removed, use the plastic opening tool to gently pry off the front case.
  6. Samsung S760 Battery Cover  Replacement Guide, Battery Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the pointed end of the Spudger, push the metal pin out of the hinge as far as it will go (this will typically be halfway).
    • It can be hard to get the Spudger point to center on the pin, so try choking up on the Spudger.
  7. Samsung S760 Battery Cover  Replacement Guide: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung S760 Battery Cover  Replacement Guide: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the tweezers, grasp and pull the portion of the pin that is sticking out of the hinge.
  8. Samsung S760 Battery Cover  Replacement Guide: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung S760 Battery Cover  Replacement Guide: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the battery cover in the same direction you pushed to open it. The cover should come right off.
Isaiah Weidmann
crwdns2935283:003/04/17crwdne2935283:0
345 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S8-G1, Catania Spring 2017 crwdns2935289:0UMass Dartmouth, Team S8-G1, Catania Spring 2017crwdne2935289:0
UMASSD-CATANIA-S17S8G1
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 90
