Samsung Refrigerator Freezer Evaporator Components Replacement
  1. Samsung Refrigerator Freezer Evaporator Components Replacement, Unplug your refrigerator: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Refrigerator Freezer Evaporator Components Replacement, Open the freezer drawer: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the freezer drawer fully open.
  3. Samsung Refrigerator Freezer Evaporator Components Replacement, Remove the freezer bins: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove all the freezer bins from the drawer.
    • You should be left with a freezer door attached by two rails.
  4. Samsung Refrigerator Freezer Evaporator Components Replacement, Remove the freezer door: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Freezer Evaporator Components Replacement, Remove the freezer door: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Freezer Evaporator Components Replacement, Remove the freezer door: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A plastic tab locks each drawer rail in place.
    • Use a flathead screwdriver to press in the plastic tab near the inner end of the drawer rail.
    • As you press the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
  5. Samsung Refrigerator Freezer Evaporator Components Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Refrigerator Freezer Evaporator Components Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the rail unlock procedure on the other drawer rail.
    • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
    • Remove the freezer drawer.
    • To install the freezer drawer:
    • Push the geared torsion bar until it rests at the very end of the rails.
    • Align the drawer rails to the refrigerator wall guides.
    • Close the freezer drawer until the rails lock back in place.
    • If you don't hear a click, visually check if the plastic tabs have locked in place. You may need to push the rails in a little further with your fingers to set the tabs.
  6. Samsung Refrigerator Freezer Evaporator Components Replacement, Remove the freezer compartment evaporator cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws securing the freezer evaporator cover.
  7. Samsung Refrigerator Freezer Evaporator Components Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Freezer Evaporator Components Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Freezer Evaporator Components Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't try to fully remove the evaporator cover yet, as it's connected to the refrigerator by a few wires in the top right corner.
    • Use your hands to lift the bottom edge of the evaporator cover up to release the lower plastic tabs.
    • Swing the evaporator cover upwards to access the connected wires behind it.
  8. Samsung Refrigerator Freezer Evaporator Components Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Refrigerator Freezer Evaporator Components Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to squeeze and disconnect the fan cable connector from the back wall of the freezer.
  9. Samsung Refrigerator Freezer Evaporator Components Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the evaporator cover.
  10. Samsung Refrigerator Freezer Evaporator Components Replacement, Disconnect the evaporator components: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Refrigerator Freezer Evaporator Components Replacement, Disconnect the evaporator components: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the metal connector cover from the top right corner of the freezer back wall.
  11. Samsung Refrigerator Freezer Evaporator Components Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use snips or scissors to cut any cable ties securing the wires.
  12. Samsung Refrigerator Freezer Evaporator Components Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Refrigerator Freezer Evaporator Components Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to squeeze and disconnect the harness connector from the refrigerator.
  13. Samsung Refrigerator Freezer Evaporator Components Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Freezer Evaporator Components Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Freezer Evaporator Components Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to pry and remove the red and white connector retaining clips from the harness connector. This will separate the connector into three individual connectors.
    • The three connectors are stacked on top of each other. The order from top to bottom is:
    • Defrost coil thermal fuse (yellow connector with two red wires)
    • One end of the defrost coil (yellow connector with brown wire in the left pin)
    • Evaporator coil thermistor (white connector with two yellow wires)
  14. Samsung Refrigerator Freezer Evaporator Components Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Freezer Evaporator Components Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Freezer Evaporator Components Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The freezer evaporator system includes these components:
    • Evaporator coil (filled with refrigerant and is non-removable)
    • Defrost heater
    • Evaporator coil thermister
    • Depending on your repair, remove and replace the affected components.
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
crwdns2935283:004/14/15crwdne2935283:0
15,927 crwdns2915208:0crwdne2915208:0
crwdns2935297:089crwdne2935297:0
Team Vulcan crwdns2935289:0Team Vulcancrwdne2935289:0
Staff
crwdns2931471:06crwdne2931471:0
crwdns2935297:0201crwdne2935297:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 127
crwdns2942667:0crwdne2942667:0 2,015
