This guide shows how to replace the evaporator thermistor in your Samsung refrigerator.
Some Samsung refrigerators have two evaporators: one for the refrigerator compartment and one for the freezer. This guide is for the refrigerator evaporator thermistor.
This thermistor does not sense the refrigerator compartment temperature. Rather, this thermistor senses the evaporator coil temperature. If this thermistor fails, your refrigerator won't cool the refrigerator compartment properly.
This guide will work for most Samsung Refrigerators . This guide is based on a model RF28R7201SG Refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same
Unplug your refrigerator before you begin your repair.
Open both French doors for the refrigerator compartment.
Remove all the loose shelves and bins from the refrigerator compartment.
Press both plastic tabs firmly with your fingers and lift upward to unclip the bottom shelf.
Remove the bottom shelf.
Use a flathead screwdriver to pry and remove the top screw cover on the evaporator cover.
Remove the screws securing the evaporator cover.
Grasp the right edge of the evaporator cover with your hands and swing it outwards toward you.
Don't try to fully remove the cover in this step, as it's connected by several wires.
Squeeze and disconnect all the wire connectors connecting the evaporator cover to the refrigerator.
Pull the evaporator cover towards you and remove it.
Use a flathead screwdriver to pry off and remove any connector retaining clips.
Use your fingers to squeeze the thermistor's connector by the sides.
Pull the connector straight out to disconnect it.
Use snips or scissors to cut any cable ties securing the thermistor cable.
Use your fingers to twist and unclip the thermistor from the evaporator coil.
Remove the evaporator thermistor.
Repair didn’t go as planned? Ask our Answers Community for help.
