Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement
  1. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Unplug your refrigerator: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Open the refrigerator doors: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Open the refrigerator doors: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open both French doors for the refrigerator compartment.
  3. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Remove the shelves: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Remove the shelves: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all the loose shelves and bins from the refrigerator compartment.
    • The bottom shelf is clipped in place. Follow the next step to remove it.
  4. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Two stiff plastic tabs (one on each side) secure the bottom shelf in place.
    • Press both plastic tabs firmly with your fingers and lift upward to unclip the bottom shelf.
    • If the shelf doesn't unclip, you can try using a flathead screwdriver to press each clip in.
    • Remove the bottom shelf.
  5. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a flathead screwdriver to pry and remove the top screw cover on the evaporator cover.
  6. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws securing the evaporator cover.
  7. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grasp the right edge of the evaporator cover with your hands and swing it outwards toward you.
    • Don't try to fully remove the cover in this step, as it's connected by several wires.
  8. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Squeeze and disconnect all the wire connectors connecting the evaporator cover to the refrigerator.
  9. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the evaporator cover towards you and remove it.
  10. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Disconnect the evaporator thermistor: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Disconnect the evaporator thermistor: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Disconnect the evaporator thermistor: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a flathead screwdriver to pry off and remove any connector retaining clips.
  11. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to squeeze the thermistor's connector by the sides.
    • Pull the connector straight out to disconnect it.
  12. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use snips or scissors to cut any cable ties securing the thermistor cable.
  13. Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Remove the evaporator thermistor: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Remove the evaporator thermistor: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Refrigerator Evaporator Thermistor (Refrigerator Compartment) Replacement, Remove the evaporator thermistor: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to twist and unclip the thermistor from the evaporator coil.
    • Remove the evaporator thermistor.
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
crwdns2935283:004/14/15crwdne2935283:0
15,927 crwdns2915208:0crwdne2915208:0
crwdns2935297:089crwdne2935297:0
Team Vulcan crwdns2935289:0Team Vulcancrwdne2935289:0
Staff
crwdns2931471:06crwdne2931471:0
crwdns2935297:0201crwdne2935297:0
crwdns2936753:030crwdne2936753:0 152
crwdns2942667:0crwdne2942667:0 1,722
