Samsung Radiant 360 R1 Motherboard Replacement
  1. Samsung Radiant 360 R1 Motherboard Replacement, Micro USB / Power Port Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Use the plastic opening tool to lift and remove the rubber grommet plugs.
  2. Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a PH1 Philips screwdriver, remove four (9.5mm x 1.6mm) screws from the base plate.
    • Remove base plate by stabilizing speaker and using plastic prying tool to pry the base plate from the speaker.
  3. Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the speaker on the table with the Touch Pad facing down. This will leave you with the Port Panel exposed.
    • Remove speaker grill by stabilizing speaker on a table and applying pressure to the bottom of the speaker. Slide the speaker grill up and away from the remaining endcap.
  4. Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two exposed (9.5mm x 1.6mm) PH1 Phillips screws on the Port Panel.
    • Remove the Port Panel from the speaker body, exposing the ribbon cables.
  5. Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While stabilizing the Port Panel remove the two ribbon cables one at a time by pressing the locking clip down on the ribbon cable connectors and pulling the connector away from the Port Panel.
    I understand this is a guide for working on the Samsung wam 1500 yourself. But where can you get the parts from. I can not find them online. I need to replace the usb/power port panel
    Brian Vickers - crwdns2934203:0crwdne2934203:0
  6. Samsung Radiant 360 R1 Motherboard Replacement, 1" Tweeter Speaker: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Radiant 360 R1 Motherboard Replacement, 1" Tweeter Speaker: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Radiant 360 R1 Motherboard Replacement, 1" Tweeter Speaker: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four (9.5mm x 1.6mm) PH1 Phillips screws on the port speaker body.
    • Remove the Port Panel exposing the subwoofer.
  7. Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the eight (9.5mm x 1.6mm) PH1 Phillips screws on the right side of the speaker body.
    • Remove the one (9.5mm x 1.6mm) PH1 Phillips screw on the left side of the speaker body.
    • The body sides are denoted with a "R" and an "L" for right and left sides.
  8. Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open up the body to expose the inner panel and motherboard.
  9. Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ribbon cable from the tweeter which is attached to the main motherboard.
    • Slide the tweeter out of the enclosure.
  10. Samsung Radiant 360 R1 Motherboard Replacement, Bluetooth Module: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide rubber grommet out of slot on plastic housing.
    • This may have occurred naturally when separating the two halves.
  11. Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect white connector by pushing down on the release tab while gently pulling the connector free from the socket.
    • Remove wiring harness and set aside.
    • The other connectors in the wiring harness should already be free from previous steps.
  12. Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate and remove the two PH2 Phillips screws from the base of the motherboard assembly.
    • These screws may be extremely tight. Be careful not to snap the plastic when removing the screws.
  13. Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the motherboard assembly over and locate the Bluetooth module on the side of the metal frame.
    • Remove the one PH2 Philips screw.
  14. Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the white tab while gently pulling the Bluetooth module away from the connector and frame.
  15. Samsung Radiant 360 R1 Motherboard Replacement, Motherboard: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Radiant 360 R1 Motherboard Replacement, Motherboard: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Radiant 360 R1 Motherboard Replacement, Motherboard: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pinch the release tab on the remaining small white connector to disconnect the final wiring harness from the motherboard.
  16. Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Radiant 360 R1 Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four PH2 Phillips screws holding the motherboard to the mounting frame.
    • Carefully separate the motherboard from the metal frame.
Aaron Bristow
crwdns2935283:009/21/17crwdne2935283:0
406 crwdns2915208:0crwdne2915208:0
Washington State, Team S5-G121, Phelps-Hillen Fall 2017 crwdns2935289:0Washington State, Team S5-G121, Phelps-Hillen Fall 2017crwdne2935289:0
WSU-PHELPS-HILLEN-F17S5G121
About to change my motherboard on R5. Do you need a software afterwards?
Marques - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 751
