Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement
  1. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Unplug your refrigerator: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Open the freezer drawer: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Open the freezer drawer: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the freezer drawer fully open.
  3. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer bins: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer bins: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer bins: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift and remove all the freezer bins from the drawer.
    • You may need to open the refrigerator doors in order to remove the large bin.
  4. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer door: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer door: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer door: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A plastic tab locks each drawer rail in place.
    • Use a flathead screwdriver or your fingers to press in the plastic tab near the inner end of the drawer rail.
    • While pressing the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
  5. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat the rail unlock procedure on the other drawer rail.
  6. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
    • Remove the freezer drawer.
    • To reinstall the freezer drawer:
    • Push the geared torsion bar until it rests at the very end of the rails.
    • Align the drawer rails to the refrigerator wall guides.
    • Close the freezer drawer until the rails lock back in place.
    • If you don't hear a click, visually check if the plastic tabs have locked in place. You may need to push the rails in a little further with your fingers to set the tabs.
  7. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 18.5 mm‑long screws securing the evaporator cover to the refrigerator.
  8. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the bottom edge of the evaporator cover away from the refrigerator to release the bottom clips.
    • Don't try to fully remove the cover. It's still connected by a few wires.
    • Shift the evaporator cover downwards to access the connectors in the top right corner of the freezer compartment.
  9. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Disconnect the fan connector: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Disconnect the fan connector: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Disconnect the fan connector: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Squeeze the bottom edge of the fan connector to unlock it from the freezer wall.
    • Pull and disconnect the fan connector.
  10. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the evaporator cover.
  11. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Loosen the fan cable: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Loosen the fan cable: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Loosen the fan cable: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Guide the fan cable out of the evaporator cover clips.
    • If you have trouble getting the cable out of the clips, squeeze the clips with pliers to create a wider gap.
  12. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the evaporator back panel: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 14.5 mm‑long screws securing the back panel to the evaporator cover.
  13. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to pry and release the clips along the short edge of the evaporator cover.
    • If the perimeter foam insulation prevents you from releasing the clips, cut the foam with scissors.
  14. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift and separate the back panel from the evaporator cover.
  15. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the evaporator fan: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the three 14.2 mm‑long screws securing the evaporator fan.
  16. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the evaporator fan.
    • During reassembly, be sure to install the fan in the right orientation: the side with the center label should face down towards the evaporator cover.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
306,319 crwdns2915208:0crwdne2915208:0
crwdns2935297:0691crwdne2935297:0
Staff
crwdns2935297:023,157crwdne2935297:0
Thanks for creating this guide, the evaporator fan on my RF28T5101SR started constantly growling after about 5 years of use. Replacement fan is silent and things are back to normal.
Dave S - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 50
crwdns2936753:030crwdne2936753:0 203
crwdns2942667:0crwdne2942667:0 4,353
