Samsung RF28R7351 Fuse Block Module Replacement
crwdns2936621:0crwdne2936621:0
  1. Samsung RF28R7351 Fuse Block Module Replacement, Fuse Box Module: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by disconnecting the power to the appliance
    • It is also recommended to test the outlet for the proper voltage
    • Also, turn off the water.
  2. Samsung RF28R7351 Fuse Block Module Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You will need a Phillips screwdriver to remove the cover, which is held on by five Phillips screws.
    • Remove the five Phillips screws.
    • The lower middle screw is a machine screw thread, so keep it separate for reinstallation.
  3. Samsung RF28R7351 Fuse Block Module Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28R7351 Fuse Block Module Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the panel removed, you now have clear access to the fuse block.
  4. Samsung RF28R7351 Fuse Block Module Replacement, Test continuity of fuses: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28R7351 Fuse Block Module Replacement, Test continuity of fuses: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The main reason why you'd be accessing your fuse block is if the unit has no power
    • Once the fuse block is removed, you can use your multimeter to test continuity on the metal sides of each one of these fuses.
    • (How to use a multimeter)
    • If one is blown, the fuse block will need to be replaced.
  5. Samsung RF28R7351 Fuse Block Module Replacement, Disconnecting the fuse block: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28R7351 Fuse Block Module Replacement, Disconnecting the fuse block: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  6. Samsung RF28R7351 Fuse Block Module Replacement, Installing a new fuse block: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28R7351 Fuse Block Module Replacement, Installing a new fuse block: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When installing your new fuse block, first install the wiring.
    • Make sure the connector is securely locked into place.
    • The red wire goes with the red, and the blue with the blue.
    • Swing it in at an angle and pop it in place.
  7. Samsung RF28R7351 Fuse Block Module Replacement, Reinstall the panel cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the new fuse block is installed, you can reinstall the panel cover.
    • To reinstall your panel cover, first bring in the top at an angle and drop it on those hooks.
  8. Samsung RF28R7351 Fuse Block Module Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung RF28R7351 Fuse Block Module Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung RF28R7351 Fuse Block Module Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
eCuration
crwdns2935283:005/19/17crwdne2935283:0
449,322 crwdns2915208:0crwdne2915208:0
crwdns2935297:0252crwdne2935297:0
crwdns2942667:0crwdne2942667:0 383
