Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement
  1. Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Unplug your refrigerator: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Open the refrigerator doors: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Open the refrigerator doors: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open both French doors for the refrigerator compartment.
  3. Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Remove the ice tray: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Remove the ice tray: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Remove the ice tray: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the ice tray straight out of its housing and remove it.
  4. Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Unfasten the cable cover panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Unfasten the cable cover panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the 16.5 mm‑long screw securing the cable cover panel.
  5. Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Remove the cable cover panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Remove the cable cover panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Remove the cable cover panel: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to slide the cable cover panel towards the front of the refrigerator to unlatch it.
    • Remove the cable cover panel.
    • During reassembly, make sure this panel clips fully in place, or the ice tray won't slide in properly.
  6. Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Disconnect the icemaker harness: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Disconnect the icemaker harness: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the left-most yellow connector:
    • Squeeze the locking tab with the red mark with your fingers
    • Rock the connector gently side to side to disconnect it
    • Use your fingers or a screwdriver to guide the wire harness out of the wall clips.
  7. Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Unfasten the air tunnel: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the 16.5 mm-long screw securing the air tunnel flap.
  8. Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Remove the icemaker assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Remove the icemaker assembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Remove the icemaker assembly: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A plastic clip holds the air tunnel flap in place.
    • Use a flathead screwdriver to pry and loosen the air tunnel flap from the plastic clip.
  9. Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to pull the air tunnel flap down enough to access the internals.
  10. Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a flathead screwdriver to gently pry the refrigerant loop down by 1–1.5 cm.
    • During reassembly, use your fingers to push the refrigerant loop back up.
  11. Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A plastic clip holds the icemaker in place.
    • Use your fingers to press and release the plastic clip.
    • This clip is stiff and may require substantial force.
  12. Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the front edge of the icemaker assembly down slightly to loosen it.
    • Be careful not to bend the refrigerant loop too much as you pull the front edge, or you'll damage the loop.
    • Carefully slide the icemaker assembly out of its housing.
  13. Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  14. Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Disconnect the auger wiring connector: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Disconnect the auger wiring connector: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the auger wiring connector:
    • Squeeze the locking tab with your fingers
    • Rock the connector side to side to loosen and disconnect it
    • Guide the wiring harness out of the retaining tabs.
    • During reassembly, make sure to re-route the wiring harness back into the retaining tabs. Otherwise, you won't be able to click the cable cover in place.
  15. Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Remove the auger assembly: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Remove the auger assembly: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement, Remove the auger assembly: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A stiff plastic clip holds the auger assembly in place.
    • While lifting the clip with a flathead screwdriver, pull the metal head of the auger assembly to separate it from the chassis.
    • This will prevent the clip from locking back in place.
  16. Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Auger Assembly Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the auger assembly out of the refrigerator and remove it.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
crwdns2935283:004/14/15crwdne2935283:0
15 927 crwdns2915208:0crwdne2915208:0
crwdns2935297:089crwdne2935297:0
Great guide!
Very well done, excellent documentation and pictures.
Thank you!
Annthony M - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 306
