Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement
  1. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unplug your refrigerator: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open both French doors for the refrigerator compartment.
  3. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the ice tray: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the ice tray: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the ice tray: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the ice tray straight out of its housing and remove it.
  4. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the 16.5 mm‑long screw securing the cable cover panel.
  5. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to slide the cable cover panel towards the front of the refrigerator to unlatch it.
    • Remove the cable cover panel.
    • During reassembly, make sure this panel clips fully in place, or the ice tray won't slide in properly.
  6. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the left-most yellow connector:
    • Squeeze the locking tab with the red mark with your fingers
    • Rock the connector gently side to side to disconnect it
    • Use your fingers or a screwdriver to guide the wire harness out of the wall clips.
  7. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unfasten the air tunnel: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the 16.5 mm-long screw securing the air tunnel flap.
  8. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A plastic clip holds the air tunnel flap in place.
    • Use a flathead screwdriver to pry and loosen the air tunnel flap from the plastic clip.
  9. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to pull the air tunnel flap down enough to access the internals.
  10. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a flathead screwdriver to gently pry the refrigerant loop down by 1–1.5 cm.
    • During reassembly, use your fingers to push the refrigerant loop back up.
  11. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A plastic clip holds the icemaker in place.
    • Use your fingers to press and release the plastic clip.
    • This clip is stiff and may require substantial force.
  12. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the front edge of the icemaker assembly down slightly to loosen it.
    • Be careful not to bend the refrigerant loop too much as you pull the front edge, or you'll damage the loop.
    • Carefully slide the icemaker assembly out of its housing.
  13. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
Repair didn’t go as planned? Ask our Answers community for help.
nicO
crwdns2935283:004/14/15crwdne2935283:0
15,927 crwdns2915208:0crwdne2915208:0
crwdns2935297:089crwdne2935297:0
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 114
crwdns2942667:0crwdne2942667:0 1,770
