Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement
  1. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Unplug your refrigerator: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Remove the upper shelves: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Remove the upper shelves: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Remove the upper shelves: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the front edge of the shelf to release it from the shelf mounts.
    • Lift the whole shelf and bring it toward the front of the refrigerator.
  3. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Remove the crisper drawers: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Remove the crisper drawers: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Remove the crisper drawers: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull out the crisper drawers to the stop.
    • Lift the front edge of the drawer and pull it the rest of the way out.
  4. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Remove the bracket above lower shelf: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a #2 Phillips driver to remove the screw securing the bracket to the shelf mount.
  5. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Remove the upper full width bottom shelf: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Remove the upper full width bottom shelf: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Remove the upper full width bottom shelf: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unlock the lower shelf by pressing in the locking tabs located on each side of the shelf right next to the crisper drawer wheels.
    • Maintain a slight upward pressure on the shelf with your hands during this process so the tabs don't click back into place.
  6. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use both hands to lift the front of the shelf up.
    • Pull the shelf towards you once it is lifted up enough to clear the retainers at the side shelf supports.
    • You should now be able to see some of the screws which hold the rear panel in place.
  7. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Access the screws for the evaporator cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Access the screws for the evaporator cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Access the screws for the evaporator cover: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a screwdriver or spudger to insert into the bottom of the screw cover, then pry upward to loosen and remove it.. Remove the cover and set it aside.
  8. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Unfasten the fresh food evaporator cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Unfasten the fresh food evaporator cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a #2 Phillips driver to remove the screws securing the evaporator cover to the rear wall of the fresh food compartment.
  9. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Reposition the evaporator cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Reposition the evaporator cover: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Reposition the evaporator cover: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grasp the lower edge of the evaporator cover and pull it forward.
    • Don't force the reposition of the evaporator cover. The cover is mainly foamed plastic, and can be broken if handled carelessly.
    • If it doesn't want to release, check for ice buildup which may show up in the small vents.
  10. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the lower edge is free pull the right edge free.
    • Rotate the evaporator cover so it faces the left side of the fresh food compartment.
  11. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Disconnect the evaporator cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Disconnect the evaporator cover: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Disconnect the evaporator cover: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Access the connectors on the left rear wall of the fresh food compartment.
    • Disconnect the wires that lead to the evaporator cover, by squeezing the locking tab on each connector and pulling the connector toward you.
  12. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finish disconnecting the evaporator cover.
  13. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Remove the evaporator cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Remove the evaporator cover: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the evaporator cover from the fresh food compartment.
  14. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Unfasten the evaporator fan assembly: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a #2 Phillips driver to remove the screws securing the fresh food evaporator fan assembly to the evaporator cover.
  15. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Unclip the fan and thermistor wires: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Unclip the fan and thermistor wires: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Unclip the fan and thermistor wires: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the thermistor wires and the wires to the evaporator fan from the evaporator fan assembly.
  16. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Separate the evaporator fan assembly: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Separate the evaporator fan assembly: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Separate the evaporator fan assembly: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the evaporator fan assembly to separate it from the evaporator cover.
  17. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Release the evaporator cover shell: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Release the evaporator cover shell: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel the tan masking tape on the left and right sides of the evaporator cover.
  18. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Lift the evaporator cover shell: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Lift the evaporator cover shell: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Lift the evaporator cover shell: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to peel the sticky foam insulation back at the top edge.
    • Lift the top edge of the plastic shell.
  19. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Free the thermistor leads: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Free the thermistor leads: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel the tan masking tape to expose the wire channel for the thermistor leads.
  20. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Free the thermistor: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Free the thermistor: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back the sticky foam insulation to further expose the channel for the thermistor leads. This is usually near the center of the evaporator cover.
    • Lift the thermistor free of its holder with your fingertips. You can use the leads gently to move it.
    • Peel back the sticky foam further, and free the thermistor leads from the channel.
  21. Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Remove the thermistor: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Remove the thermistor: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Older French Door Refrigerator Fresh Food Thermistor Replacement, Remove the thermistor: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Thread the thermistor leads under the sticky foam insulation along with the thermistor.
    • Remove the thermistor completely.
Repair didn’t go as planned? Ask our Answers Community for help.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
37,849 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,981crwdne2935297:0
crwdns2942667:0crwdne2942667:0 121
