Samsung Mythic SGH-a897 Microphone Replacement
  1. Samsung Mythic SGH-a897 Microphone Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
  2. Samsung Mythic SGH-a897 Microphone Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place your finger on either bottom corner of the battery slot and lift to remove the battery.
  3. Samsung Mythic SGH-a897 Microphone Replacement, Rear Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
  4. Samsung Mythic SGH-a897 Microphone Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
    • Working along the seam, pry the back casing from the phone.
  5. Samsung Mythic SGH-a897 Microphone Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the two 3.8mm screws.
  6. Samsung Mythic SGH-a897 Microphone Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Mythic SGH-a897 Microphone Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, firmly grip the black lever at the bottom of the motherboard.
    • Use the tweezers to flip the black lever up so that it is upright from the motherboard.
  7. Samsung Mythic SGH-a897 Microphone Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ZIF cable by carefully using the tweezers to pull the cable straight out.
  8. Samsung Mythic SGH-a897 Microphone Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Mythic SGH-a897 Microphone Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the right from the lever, use the tweezers to unclip the black connector.
  9. Samsung Mythic SGH-a897 Microphone Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Mythic SGH-a897 Microphone Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tweezers to unclip the orange ribbon cable from the left side of the phone.
  10. Samsung Mythic SGH-a897 Microphone Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the tweezers to unclip the other orange ribbon cable along the left side of the phone.
    • Work carefully, as this is a very delicate part of the phone's motherboard that can easily be broken.
  11. Samsung Mythic SGH-a897 Microphone Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Mythic SGH-a897 Microphone Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using either side of the tweezers, slide a side of the tweezer underneath the red and blue wires and the capacitor.
    • Carefully lift the capacitor away from the phone.
  12. Samsung Mythic SGH-a897 Microphone Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Mythic SGH-a897 Microphone Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • DO NOT remove the motherboard completely. One more clip on the motherboard's backside needs to be removed.
    • Carefully tilt the motherboard up from the back of the phone.
    • Use tweezers to unclip the black connector.
  13. Samsung Mythic SGH-a897 Microphone Replacement, LCD: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Mythic SGH-a897 Microphone Replacement, LCD: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the phone by the black plastic at the ends and gently bend them down so that the middle of the phone is the highest point. Apply pressure slowly until the grey portion pops off.
  14. Samsung Mythic SGH-a897 Microphone Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Mythic SGH-a897 Microphone Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Mythic SGH-a897 Microphone Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tweezers into the hole to wedge them between the LCD and grey plastic.
    • Once under the LCD, slide the tweezers around the three silver edges until the entire display lifts from the grey plastic.
  15. Samsung Mythic SGH-a897 Microphone Replacement, Microphone: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Mythic SGH-a897 Microphone Replacement, Microphone: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Find the rubber microphone backing on the bottom of the back of the front cover as shown in the picture.
    • Use tweezers to remove the microphone from the casing.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Collin Gordon
crwdns2935283:004/08/13crwdne2935283:0
45 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-1, Regan Spring 2013 crwdns2935289:0Cal Poly, Team 17-1, Regan Spring 2013crwdne2935289:0
CPSU-REGAN-S13S17G1
crwdns2935297:018crwdne2935297:0
crwdns2942667:0crwdne2942667:0 392
