Samsung Level Box Mini Battery Replacement
dylan weiss
crwdns2944107:0crwdnd2944107:0dylan weisscrwdnd2944107:0crwdnd2944107:0crwdnd2944107:03crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Kul 5, 2025crwdne2944111:0
crwdns2931287:05crwdne2931287:0
crwdns2937799:0crwdne2937799:0
crwdns2942287:0crwdne2942287:0
If the Samsung Level Box Mini is not charging, not turning on, or if the battery is losing power rapidly, then the batteries may require replacement.
crwdns2944105:0crwdne2944105:0
  1. Samsung Level Box Mini Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Level Box Mini Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, go around the edges of the rubber bottom. Insert the same tool under the edge of the rubber and swivel side to side. Continue moving it forward while peeling the plastic off with the precision tweezers.
    Excellent instructional only addition is to be careful with the rubber pad and adhesive tape do not use sharp tool that could get between adhesive and rubber pad… Lay pad on a clean dust dirt fuzz free surface as you will need this to re-adhere to the base when I did mine It was so adhered I thought I was doing something wrong. No worry with patience and persistence it does reluctantly come off.
    Danielle Wissert - crwdns2934203:0crwdne2934203:0
  2. Samsung Level Box Mini Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 4.5 mm Philips #1 screws from the bottom plate using the Screwdriver J00. Take off the bottom plate.
  3. Samsung Level Box Mini Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, remove the batteries from the device.
    This repair guide is less useful considering the part number for the battery is not included. There are a number of different Samsung batteries available for different devices. Since you already had the cover off, why not post the part number so that readers can order the correct part?
    Lenny Tompkins - crwdns2934203:0crwdne2934203:0
    I concur. Finding the right battery is a pain
    bob - crwdns2934203:0crwdne2934203:0
To reassemble your device, follow all the instructions in the reverse order. Use adhesive to stick the rubber back onto the bottom of the device.
crwdns2935229:08crwdne2935229:0
dylan weiss
crwdns2935283:002/16/17crwdne2935283:0
134 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-4, Kass Spring 2017 crwdns2935289:0USF Tampa, Team 1-4, Kass Spring 2017crwdne2935289:0
USFT-KASS-S17S1G4
crwdns2947412:05crwdne2947412:0
Did all above but still wont switch on..batt are ok and power gets to the battery points…what could be wrong…
dslotman5 - crwdns2934203:0crwdne2934203:0
I want to replace pcb of this device how to find it??
faraz siddiqui - crwdns2934203:0crwdne2934203:0
I want to replace PCB of this device suggest me where to find?
The "parts needed" list has a search for the battery misspelled in "Samsung".
Jim Plosay - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 68
crwdns2942667:0crwdne2942667:0 9,181
