Have your applications or watch become unresponsive? Replacing the motherboard may fix these issues.
Flip the watch over so that the face is down.
Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
Using your finger, push forward on the release while pulling up on the strap.
The bracelet should be removed first!
Das Armband sollte zuerst entfernt werden!
Repeat the procedure from step 2 for the other strap.
Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
My watch had sticky glue between the top and bottom portions of the case. I don’t think my watch will be as waterproof after this repair.
Using a Philips head #00 screwdriver, remove the two 3.6 millimeter screws.
Using a spudger, pry up the three cables.
Using the flat end of a spudger, pry up the motherboard.
The motherboard is attached to the battery casing, so place the motherboard in the orientation shown once freed.
Where do you get the mother board.
I'm looking for a new motherboard as well.
Karen -
Where do you buy a motherboard???
Do you have a good source for motherboards? Hope it helps that I +30’d you!
Ok motherboard replaced but how can I have the watch to work in normal mode and not in factory release.?
I damaged one of the cables. Can I but a watch for parts to replace the cable or should I just cut my loses?
The warning to turn off the watch to avoid electrical shock was a joke, right?!
nanev - crwdns2934203:0crwdne2934203:0
The screws don't seem to be turning easily. What's the best way to loosen them without stripping them?
Mark Franz - crwdns2934203:0crwdne2934203:0
I’m going to be shocked by a dead 3.8V battery? Of course, only if the watch is powered on. Ridiculous statements like this do not reflect positively on the credibility of this entire procedure. If the author seriously thinks this is a danger then I question your basic understanding of electronics.
Alex Tatistcheff - crwdns2934203:0crwdne2934203:0
… to avoid being shocked when you lose your data! :)
Reuben Janzen-Martin - crwdns2934203:0crwdne2934203:0
