Samsung Gear S2 Back Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Samsung Gear S2 Back Replacement, Watch Strap: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S2 Back Replacement, Watch Strap: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the watch over so that the face is down.
    • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Remember to turn off the watch to avoid being shocked.
    The warning to turn off the watch to avoid electrical shock was a joke, right?!
    nanev - crwdns2934203:0crwdne2934203:0
    The screws don't seem to be turning easily. What's the best way to loosen them without stripping them?
    Mark Franz - crwdns2934203:0crwdne2934203:0
    I’m going to be shocked by a dead 3.8V battery? Of course, only if the watch is powered on. Ridiculous statements like this do not reflect positively on the credibility of this entire procedure. If the author seriously thinks this is a danger then I question your basic understanding of electronics.
    Alex Tatistcheff - crwdns2934203:0crwdne2934203:0
    … to avoid being shocked when you lose your data! :)
    Reuben Janzen-Martin - crwdns2934203:0crwdne2934203:0
  2. Samsung Gear S2 Back Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S2 Back Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your finger, push forward on the release while pulling up on the strap.
    • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
    The bracelet should be removed first!
    Das Armband sollte zuerst entfernt werden!
    Wilhelm Gregorius - crwdns2934203:0crwdne2934203:0
  3. Samsung Gear S2 Back Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S2 Back Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the procedure from step 2 for the other strap.
  4. Samsung Gear S2 Back Replacement, Back: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S2 Back Replacement, Back: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
    • Do not insert the tool more than 3 millimeters into the case. Inserting more than 3 mm may damage the seal and electric components.
    My watch had sticky glue between the top and bottom portions of the case. I don’t think my watch will be as waterproof after this repair.
Jacob Baldwin
crwdns2935283:002/20/17crwdne2935283:0
3,432 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G3, Sullivan Spring 2017 crwdns2935289:0USF Tampa, Team S2-G3, Sullivan Spring 2017crwdne2935289:0
USFT-SULLIVAN-S17S2G3
crwdns2935297:023crwdne2935297:0
And where do you get the new replacement back? And does it just snap back on?
shawntravis76 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 446
