Samsung Gear Live Heart Rate Monitor Replacement
  1. Samsung Gear Live Heart Rate Monitor Replacement, Lay the watch face-down: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the watch face-down on a flat, stable surface.
    Be sure to proofread carefully.
    Dan Brown - crwdns2934203:0crwdne2934203:0
  2. Samsung Gear Live Heart Rate Monitor Replacement, Remove the holding pin: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the watchband down against the work surface.
    • Press the tip of a flathead screwdriver against the edge of the spring-loaded holding pin.
  3. Samsung Gear Live Heart Rate Monitor Replacement, Remove the watchband: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the spring-loaded pin pressed in, the watch band should release easily.
    • Gently pull the band away from the body of the watch.
    • Repeat steps 2 and 3 for the opposite side.
  4. Samsung Gear Live Heart Rate Monitor Replacement, Locate the four screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the watch laying face-down, locate the four screws. They are located on the back of the watch, at the four corners.
  5. Samsung Gear Live Heart Rate Monitor Replacement, Remove the 4 screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Torx-T5 screwdriver, remove each of the four 4mm screws and set them aside.
  6. Samsung Gear Live Heart Rate Monitor Replacement, Pry off the back of the watch.: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently work the plastic opening tool under the top edge of the watch’s back cover.
  7. Samsung Gear Live Heart Rate Monitor Replacement, Lift off the back cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear Live Heart Rate Monitor Replacement, Lift off the back cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the watch’s back cover pried loose, gently lift it away from the front half of the watch.
  8. Samsung Gear Live Heart Rate Monitor Replacement, Set both halves of the watch aside: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay both halves of the watch body assembly face down (with internal components facing up).
  9. Samsung Gear Live Heart Rate Monitor Replacement, Pry away the ribbon cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear Live Heart Rate Monitor Replacement, Pry away the ribbon cable: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the ribbon cable connector near the edge of the watch's case.
    • Using the plastic opening tool, gently pry the connector from the motherboard
    You forgot the second ribbon for the vibrator motor.
    Rebecca Montgomery - crwdns2934203:0crwdne2934203:0
  10. Samsung Gear Live Heart Rate Monitor Replacement, Remove the red spacers: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear Live Heart Rate Monitor Replacement, Remove the red spacers: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, gently pry away the red spacers.
    • Set the spacers aside.
  11. Samsung Gear Live Heart Rate Monitor Replacement, Pry up the motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Gear Live Heart Rate Monitor Replacement, Pry up the motherboard: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Gear Live Heart Rate Monitor Replacement, Pry up the motherboard: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the end of the plastic opening tool under the motherboard.
    • Gently pry up the motherboard.
  12. Samsung Gear Live Heart Rate Monitor Replacement, Remove the heart rate sensor cable: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear Live Heart Rate Monitor Replacement, Remove the heart rate sensor cable: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Set the motherboard on a flat, stable surface.
    • Using the plastic opening tool, gently pry the heart rate sensor cable from the motherboard.
  13. Samsung Gear Live Heart Rate Monitor Replacement, Pry up the heart rate sensor: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Gear Live Heart Rate Monitor Replacement, Pry up the heart rate sensor: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Gear Live Heart Rate Monitor Replacement, Pry up the heart rate sensor: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the cable is disconnected, run the plastic opening tool under the heart rate sensor from all sides, gently prying up as you go along.
Keith Cooper
crwdns2935283:009/25/14crwdne2935283:0
1 265 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-7, Brown Fall 2014 crwdns2935289:0USF Tampa, Team 1-7, Brown Fall 2014crwdne2935289:0
USFT-BROWN-F14S1G7
Check all of your guides to make sure you've indicate the needed tools.
crwdns2942667:0crwdne2942667:0 1,675
