Samsung Galaxy Watch5 Motherboard Replacement
  1. Samsung Galaxy Watch5 Motherboard Replacement, Remove the watch band: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take your watch off the charger and power it down.
    • Remove the watch band.
  2. Samsung Galaxy Watch5 Motherboard Replacement, Unfasten the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Tri-point Y00 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
  3. Samsung Galaxy Watch5 Motherboard Replacement, Pry the back cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch5 Motherboard Replacement, Pry the back cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to loosen the gasket and create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
  4. Samsung Galaxy Watch5 Motherboard Replacement, Disconnect the sensor flex cable: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch5 Motherboard Replacement, Disconnect the sensor flex cable: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the watch screen-side down.
    • Carefully swing open the back cover at the gap you just created.
    • Use a spudger to disconnect the sensor flex cable from the motherboard by prying the press connector straight up from its socket.
    • During reassembly, this is a good point to turn on your device and test your repair before resealing it.
  5. Samsung Galaxy Watch5 Motherboard Replacement, Remove the back cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch5 Motherboard Replacement, Remove the back cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back cover.
    • During reassembly:
    • Make sure the rubber gasket (marked in red) is undamaged. If damaged, replace it with a new one to maintain water resistance.
  6. Samsung Galaxy Watch5 Motherboard Replacement, Disconnect the display flex cable: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch5 Motherboard Replacement, Disconnect the display flex cable: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
  7. Samsung Galaxy Watch5 Motherboard Replacement, Disconnect the button flex cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch5 Motherboard Replacement, Disconnect the button flex cable: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the button flex cable by prying the connector straight up from its socket.
  8. Samsung Galaxy Watch5 Motherboard Replacement, Unfasten the motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the single 4.4 mm–long screw securing the motherboard.
  9. Samsung Galaxy Watch5 Motherboard Replacement, Remove the motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch5 Motherboard Replacement, Remove the motherboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers or your fingers to lift the motherboard out from the watch, clearing the two flex cables.
If possible, turn on your device and test your repair before resealing.
Manuel Haeussermann
crwdns2935283:007/13/22crwdne2935283:0
22,014 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
Staff
crwdns2935297:023,153crwdne2935297:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 83
crwdns2942667:0crwdne2942667:0 2,088
