Samsung Galaxy Watch4 Battery Replacement
  1. Samsung Galaxy Watch4 Battery Replacement, Power down your Galaxy Watch4: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Samsung Galaxy Watch4 Battery Replacement, Unscrew the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws.
    The correct tool to use here is a tri-point Y00 screwdriver.
    David C - crwdns2934203:0crwdne2934203:0
    Yes this step needs to be edited as the correct tool is y00 not y000. I think I stopped my brand new y000 before I figured it out.
    Ryan Stokes - crwdns2934203:0crwdne2934203:0
    Idk guys in my case the Y000 fit much better, the Y00 did turn the screws but felt like it will strip at any moment.
    Adam Duda - crwdns2934203:0crwdne2934203:0
  3. Samsung Galaxy Watch4 Battery Replacement, Wedge open the back cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch4 Battery Replacement, Wedge open the back cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
    That isn't glue holding the cover in place. That is the rubber gasket used to waterproof the device. It WILL get damaged and you WILL have to replace it.
    Is there a way to remove the casing without damaging this gasket?
    Cove Shores -
  4. Samsung Galaxy Watch4 Battery Replacement, Disconnect the sensor flex cable: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch4 Battery Replacement, Disconnect the sensor flex cable: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the watch face down.
    • Carefully swing open the back cover by folding the back cover to the opposite site of the created gap.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  5. Samsung Galaxy Watch4 Battery Replacement, Remove the back cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover.
    • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
    If there is then what do I do and also how do I know if it's damaged
    Zev Kaff - crwdns2934203:0crwdne2934203:0
  6. Samsung Galaxy Watch4 Battery Replacement, Unscrew the motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
  7. Samsung Galaxy Watch4 Battery Replacement, Disconnect the display flex cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch4 Battery Replacement, Disconnect the display flex cable: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the display flex cable.
    on watch 4 classic variants there is an additional small connector to the left of the display connector for the rotating dial that will have to be disconnected
    Erik Port - crwdns2934203:0crwdne2934203:0
  8. Samsung Galaxy Watch4 Battery Replacement, Disconnect the side buttons: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch4 Battery Replacement, Disconnect the side buttons: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the flex cable of the crown buttons.
  9. Samsung Galaxy Watch4 Battery Replacement, Remove the motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch4 Battery Replacement, Remove the motherboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
  10. Samsung Galaxy Watch4 Battery Replacement, Lever up the battery: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch4 Battery Replacement, Lever up the battery: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the tip of an opening pick in the small gap between the plastic frame and the battery, opposite to the display cable.
    • Carefully lever the battery up and out of its recess.
    • Don't try to remove the battery completely yet, as its connector is still adhered to the core assembly.
  11. Samsung Galaxy Watch4 Battery Replacement, Release the battery connector: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Watch4 Battery Replacement, Release the battery connector: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery up a little in order to access its glued down connector cable.
    • Use a pair of blunt tweezers to lift up the battery connector which is secured with some light adhesive.
    • You will most likely be able to re-use the adhesive to fix the new battery in place. If not replace it with double sided or pre-cut adhesive tape.
  12. Samsung Galaxy Watch4 Battery Replacement, Remove the battery: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
crwdns2935229:043crwdne2935229:0
Adriana Zwink
crwdns2935283:012/18/19crwdne2935283:0
57.053 crwdns2915208:0crwdne2915208:0
crwdns2935297:0167crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020.036crwdne2935297:0
crwdns2947412:014crwdne2947412:0
Will this same battery work for the 42mm Galaxy Watch 4 Classic? Or will I need to keep searching for a replacement for that model?
geeowens - crwdns2934203:0crwdne2934203:0
No! The batteries are completely different sizes.
David C -
Guide worked very well for me on the Watch4 (not classic). My battery adhesive came off during the replacement, so it was good to have gotten the adhesive card just in case.
My only note is that the Y000 Tri-point was tool small for the 2nd step. I used the Y00 Tri-point and it worked perfectly. The battery did take some effort to get out. I also used the flat edge of the plastic spudger to help lever up the corner to slide the pick in better.
Chris - crwdns2934203:0crwdne2934203:0
If you are careful, it still is.
Kartosh (regeditexe) -
It's sad and insanely corrupt that Samsung designed this watch to make changing the battery a long, delicate, tedious and potentially hazardous process. It would have been easy for them to simply design the watch with the battery being the FIRST thing you encounter when you take off the back! They clearly want people to simply buy a new watch when the thing can't hold a charge. This is planned obsolescence and, frankly, should be illegal. Obviously that also applies to all kinds of products/devices from other manufacturers as well. It's a damned shame that so many things wind up polluting landfills because they are designed to be virtually unable to be maintained and/or repaired.
Nick Lento - crwdns2934203:0crwdne2934203:0
This comment is absolutely spot on. I couldn't have said it better myself. I find it utterly infuriating how perfectly good products end up being thrown away just because the battery is either very difficult to remove without potential damage to the device, or impossible to remove in the first place, (looking at you Sphero)
Jon Hidden-Coley -
Will the Samsung Galaxy watch 5 pro or regular battery fit in the four for longer life aren't they the same size
Michel Bergeron - crwdns2934203:0crwdne2934203:0
I got my samsung tab s7+ battery replaced. After getting the batter replaced my battery life was not as good. Then I dialed a code I.e. *#9900# and reset battery stats. After that my battery worked better. Is there some same way in galaxy watch 4?
Udit Bansal - crwdns2934203:0crwdne2934203:0
The ribbon cable came off the watch back when separating the back from the watch. Is there any way to reattach it to the back?
Robin L Bell - crwdns2934203:0crwdne2934203:0
Super clear guide, thanks!
On my first attempt I found out that I got the wrong battery (EB-BR890ABU, instead of the EB-BR890ABY), but that was easily solved. And the second attempt took only a few minutes to complete: experience 😉 It gives a lot of satisfaction to do these small repairs with success. Thanks, iFixit!
Paul Warmer - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 127
crwdns2936753:07crwdne2936753:0 663
crwdns2936753:030crwdne2936753:0 2,801
crwdns2942667:0crwdne2942667:0 89,956
