Samsung Galaxy Tab S 8.4 Back Cover Replacement
  1. Samsung Galaxy Tab S 8.4 Back Cover Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab S 8.4 Back Cover Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
    You could try a credit card, avoid metal tools.
    Isaac Pettis -
    The battery is still connected at this stage so, yes, avoid metal tools.
    Once the outer frame was mostly unclipped with the opening tool, I found the ifixit triangle plastic picks useful. As well as clips around the 4 edges there are maybe 4 more clips in the centre of the back cover that are a challenge.
    Make sure the display screen and logic boards and battery all come out in one bundle, just leaving a bare plastic back shell. Others have reported that if you separate the screen from the boards you’ll invariably break a ribbon cable and lose touch sensitivity.
    Michael Morjanoff - crwdns2934203:0crwdne2934203:0
  2. Samsung Galaxy Tab S 8.4 Back Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Back Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover after the entire rim is disconnected.
    I did some diy fixing because my tab-s came having issues. All battery connection related. Easy fix about 10 minutes but now the back cover won't sit flush and there's a large gap…idk what to do now it's infuriating there no broken tabs or connections
    Jason Carlson - crwdns2934203:0crwdne2934203:0
crwdns2935229:012crwdne2935229:0
Tara Fussell
crwdns2935283:010/01/15crwdne2935283:0
996 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-15, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 12-15, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S12G15
This is great and the process works fine. The query is where does one purchase a new back cover
Alan - crwdns2934203:0crwdne2934203:0
Hi, where can I buy the back cover of Samsung galaxy tab S 8.4. Tnx
Abe Madrigal - crwdns2934203:0crwdne2934203:0
Hi, where can I buy the back cover of Samsung galaxy tab s 8.4. Ty
crwdns2942667:0crwdne2942667:0 13,776
