This replacement guide will show you how to replace the battery in your Samsung Galaxy Tab E Lite 7 Kids. You will need to follow the instructions carefully as to not damage any fragile components in your tablet.
Using a plastic opening tool, wedge in the seam between the screen and the case.
Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
After separating the latches holding the screen and case together, slowly take the screen off the case.
Use the plastic opening tool to gently lift the black ZIF (zero insertion force) connector shown within the red circle.
Use your hands to pull the black cable out of its slot.
Use the plastic opening tool to gently lift black ZIF (zero insertion force) connector shown within the red square.
Now gently pull out the battery's ribbon cable.
Use the plastic opening tool and gently pry out the battery from the left-hand side.
Grab the battery and lift it up.
My keyboard is popping up so I can unlock the tablet is a Samsung tab e lite
crwdns2935229:05crwdne2935229:0
Great information. You need to show how to replace a screen- LCD for a Samsung Galaxy TAB E Lite Kids.
