Samsung Galaxy Tab A 9.7 Display Digitizer Replacement
crwdns2942287:0crwdne2942287:0If the glass on the screen of your Samsung Galaxy Tab A 9.7 is cracked or damaged in any way, your device could be nearly unusable. This guide will help you replace the display glass in an easy and safe way.
crwdns2944105:0crwdne2944105:0
Microwave the iOpener for 30 seconds.
Place the iOpener on each side of the screen for 30 seconds.
Take a metal spudger and wedge it between the screen and the glass.
Avoiding the screen itself, run the spudger along the perimeter of the device to weaken the glue between the glass and screen, and pry the glass off.
Using a suction cup, gently remove the screen from the device.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:04crwdne2947412:0
This is not entirely correct. For the proper way to replaced this glass, you need to remove the back cover as well, in order to connect the digitizer flex cable to the board.
incomplete.
Not a good tutorial.
The following steps are completely missing:
- remove the backcover with a pick or Spudger running between back cover and body.
- flip up the lock for the flex cable with a spudger
- slide the flex cable through the body and remove the display
- slide the flex cable of a new display throught the body to the backside
- connect the flex cable to the connector (be aware of correct aligning) and flip down the lock
- glue the display back to the body (do not use much pressure as it may crack the new display!)
- clip back on the back cover
