Samsung Galaxy Tab A 9.7 Charging Port Replacement
  1. Samsung Galaxy Tab A 9.7 Charging Port Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
  2. Samsung Galaxy Tab A 9.7 Charging Port Replacement, Speakers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab A 9.7 Charging Port Replacement, Speakers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 2.8 mm Phillips #000 screws from the speakers.
  3. Samsung Galaxy Tab A 9.7 Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Heavy-Duty Spudger
    • Each speaker is now only connected to the main device by small plastic snaps.
    • Pry the speakers from the device at these two points using the heavy duty spudger.
  4. Samsung Galaxy Tab A 9.7 Charging Port Replacement, Charging Port: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab A 9.7 Charging Port Replacement, Charging Port: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab A 9.7 Charging Port Replacement, Charging Port: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 2.8mm #000 Phillips screws that hold the charging port and headphone jack in place.
  5. Samsung Galaxy Tab A 9.7 Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the green square connector from the motherboard. To do so, put the flat end of the plastic opening tool underneath the connector and push down.
    • During reassembly, two clicks signify the charging board is completely attached to the motherboard.
  6. Samsung Galaxy Tab A 9.7 Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Heavy-Duty Spudger
    • Place the heavy duty spudger underneath the charging port and push down to remove the charging port.
    • To reinsert the charging port, angle the port downwards towards the battery. Then press down the outside edge of the charging port.
  7. Samsung Galaxy Tab A 9.7 Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel the charging assembly from the device to completely remove the charging port from the device.
crwdns2935229:018crwdne2935229:0
Paulina Nguyen
crwdns2935283:004/26/17crwdne2935283:0
982 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G3, Livingston Spring 2017 crwdns2935289:0Cal Poly, Team S1-G3, Livingston Spring 2017crwdne2935289:0
CPSU-LIVINGSTON-S17S1G3
crwdns2947412:09crwdne2947412:0
Note that you have to transfer the shroud over the charge port from the old assembly to the new one, if the replacement part wasn’t supplied with it. This threw me when I was screwing the new unit in, until I inspected the old part more closely. Also, it takes a lot more effort than you would expect to undo the case in the first place!
Lee Cooke - crwdns2934203:0crwdne2934203:0
How did you glue it on to the new board? Which glue did you use
swordart -
Taking the cover off wasn’t the easiest, but after that it went really smooth. Thanks for the instructions! It really helped a lot! Got my tablet charging again, so I am satisfied!
Brandon Congdon - crwdns2934203:0crwdne2934203:0
there was a tape glued to right part of charging assembly and also part under the right speaker. is it a conductive tape, should it be replaced ? because once peeled off old assembly part, its difficult to put it back on the new one..
Anthony Ménagé - crwdns2934203:0crwdne2934203:0
Are the instructions the same for the SM-P550?
R T - crwdns2934203:0crwdne2934203:0
Great tutorial. Fixed my Tab. If you have the 9.7 w/pen there’s one extra connection on the charging assembly next to the speaker that you have to unplug before you peel out the assembly.
Did you reconnect this piece to the replacement part? I dont see how it can be reattached
Stacey Cerminaro -
Can someone tell me about what kind of a glue I need to put the shroud on the new
swordart - crwdns2934203:0crwdne2934203:0
great tutorial!
I’m trying to repair my motherboard and to do so i must replace a component which is burnt… can you please help me to find out what component is?
This is a picture of the component.
<a href="https://ibb.co/mHQ0k5D"><img src="https://i.ibb.co/SKqcbws/Inked-IMG-20191... alt="Inked-IMG-20191110-204740-LI" border="0"></a>
Thank you!
Vincenzo Difino - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 124
crwdns2942667:0crwdne2942667:0 27,924
