To replace other parts inside your Samsung Galaxy Tab A 10.1, you must first open up the device through the back. This guide will show you how to remove the back panel of the device.
Have the front of the device facing you.
Begin near one of the curved edges of the device (see photo two for visual example).
Place a plastic opening tool between the front and back panels.
Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
Lift the back panel off of the device.
crwdns2935229:010crwdne2935229:0
Why need to remove cables when only the back has to be replaced ?
AWESOME!! I was trying to open it from the “NOT OK” place and you saved me to broken the screen… thanks!!
David Leiva - crwdns2934203:0crwdne2934203:0
No problem, enjoy.
Roger L. Ortiz -
Felt it was easier for me to do it from the middles out.
Tanin Garcia - crwdns2934203:0crwdne2934203:0
@rogerlortiz You two seem to be miscommunicating. The author points out the location between the digitizer and frame in which to place a tool. While @Tanin Garcia, whom no longer seems to be member, was pointing out where along the edge from corner to corner it was best to start the separating process.
B. A. Computer Services -
Important: the display is sourrounded with a plastic frame. You need to get beween this frame an the backcover (not directly at glass edge as I tried it first and almost broke the glass). Get a closeup picture of it to clarify.
Oliver Dawid - crwdns2934203:0crwdne2934203:0
wer lesen kann, ist klar im Vorteil - ich hab die SD-Karte drin gelassen. Hat aber funktioniert…
Thomas Wolter - crwdns2934203:0crwdne2934203:0
Don’t use a very small flathead screwdriver as a spudger. Just shattered the screen :(
nikvoss - crwdns2934203:0crwdne2934203:0
Yes, shattered the screen. To the garbage, it goes. A little knowledge is a dangerous thing. This a repair better suited for a professional repair! Thanks for helping me make the decision to get another one!
vancega - crwdns2934203:0crwdne2934203:0
