Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement
  1. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Rear Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and Micro SD cards.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
    How do u find the tool to open it
    Gm - crwdns2934203:0crwdne2934203:0
    u can go and search on trade me
    armaan devgun -
    NOTE: Make sure to remove both the SIM card and the Micro SD card prior to disassembly. Failure to do so could result in broken parts.
    Cameron - crwdns2934203:0crwdne2934203:0
  2. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
  3. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
  4. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel up the detachable corner of the white plastic sticker that reads “pull (hands only).”
    • Remove the sticker to form a tab.
  5. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your thumb and index finger, pinch the tab and pull it up to remove the top right corner of the battery from the front panel assembly.
    • If battery resistance is encountered due to adhesive, use the flat end of a spudger to run in between the battery and the front panel assembly.
    • Do not completely detach the battery just yet, doing so can cause damage to the red and blue cables loacted at the bottom of the battery.
  6. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Starting at the bottom left side of the battery, gently remove the green tape.
    • Salvage the green tape if the replacement battery does not include one.
  7. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Run the spudger under the battery to disconnect the red and blue cable connector from the circuit.
    • Lift the battery towards you, away from the front panel.
crwdns2935229:017crwdne2935229:0
Ofelia Cruz
crwdns2935283:009/14/15crwdne2935283:0
1,119 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team 1-3, Bruce Fall 2015 crwdns2935289:0CSU Fullerton, Team 1-3, Bruce Fall 2015crwdne2935289:0
CSUF-BRUCE-F15S1G3
Everything in this guide looks pretty good. The only thing I would add to step one is to make sure you remove both the SIM card and the Micro SD card. Failure to do so can result in a broken SIM/SD card, slot or board they are connected to.
Worked great! Would have been better if I had the pry tools though. I am getting them next week :}
Jason Stephens - crwdns2934203:0crwdne2934203:0
In order to open, I did not want to purchase a pry tool so I used a think screwdriver to open abit and inserted an old credit card that made the job without danger.
Carlos Blanquer Bogacz - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 26,429
