Samsung Galaxy Tab 3 8.0 Motherboard Replacement
  1. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Battery - Open up the tablet: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Battery - Open up the tablet: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
    Separating the back cover was the hardest part of the procedure for me (a retired electrical/software engineer). I used a large flat screwdriver blade instead of the hard plastic tool shown. Go slow all the way around the tablet and expect pops as the pieces separate. I was not able to re-connect the back cover completely, accepting a paper-thin gap about 30% around the cover, but it is secure.
    Rick Nungester - crwdns2934203:0crwdne2934203:0
  2. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Remove Back Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Remove Back Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
    Peter how do I know which charging port I need thank you I don't know how else to reach you Tom Patrick mlc@earthlink.net all small case and no spaces thank you
    Tom Patrick - crwdns2934203:0crwdne2934203:0
    Yikes. I began carefully prizing off the screen - but when it finally came away the connector (near the top of the screen, about 1” from the right side) got ripped, so the unit is damaged beyond repair. I think it would have been helpful if your guide had warned us about this possibility and given some advice about how to make sure it doesn’t happen. I now have a broken tablet and a brand new battery, likewise of no use to me. Pretty heartbroken - the unit had been working fine, mainstay of daily use.
    goodone - crwdns2934203:0crwdne2934203:0
    For any future people repairing their tablets. DO NOT REMOVE THE SCREEN. I thought my tablet was a Tab 2, but no it was a Tab 3. No heat guns needed. I ended up cracking my screen a bit. I don’t know the extent of the damage yet, but Im probably going to get a replacement screen. You need to pop out the whole thing. Not just the front screen. The reason being that there’s a sort of metal scaffolding holding the screen and the back together. This needs to be separated to put in the new charging port.
    Matt -
  3. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Disconnect Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Disconnect Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  4. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Remove Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
    You don't have to, just be careful with battery connector.
    Kyoko Hori - crwdns2934203:0crwdne2934203:0
    You have to be very careful with the battery connector. On mine, the plug was difficult to remove from the base and I ended up breaking the connections between the base and the circuit board. Maybe use the pry tool to hold the base down while easing out the plug.
    Hugh Morrison - crwdns2934203:0crwdne2934203:0
    I just did the same thing Hugh...does that mean my tablet is trashed? Can it be repaired?
    tlibert -
    There’s also a pull tab on with label printed on the batery to make the pulling easier.
    IMI Comp - crwdns2934203:0crwdne2934203:0
  5. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Disconnect Speakers: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Disconnect Speakers: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the relays attached to the motherboard.
  6. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Unscrew Speakers: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Unscrew Speakers: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Unscrew Speakers: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 2.9mm screws from the speakers using a Phillips head #000 screwdriver, then lift the speakers from the device.
  7. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Disconnect All Relays: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Disconnect All Relays: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic remover tool carefully unseat the four rectangular electric leads from the board. Each rectangle is a different size, the first one is large, the second one is medium, and the last two are small.
    • Using the plastic remover tool carefully unseat the square electric lead (marked in orange) from the board.
    • Using the plastic remover tool carefully unseat the small square and the two rectangular electric leads (marked in yellow) from the board.
  8. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Unscrew Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Unscrew Motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Unscrew Motherboard: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the one 2.9mm Phillips #000 screw above the battery, and the three 2.9mm Phillips #000 screws to the right of the battery.
  9. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Remove the Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Remove the Motherboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the board from the device.
    remove camera mentioned in step 7 before doing this
    as well as disconnecting the 3 connectors at the bottom n vm
    also note that the top left black square comes out with the motherboard
    Kerri - crwdns2934203:0crwdne2934203:0
crwdns2935229:014crwdne2935229:0
Kyle Ballard
crwdns2935283:009/22/14crwdne2935283:0
951 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 4-2, Brown Fall 2014 crwdns2935289:0USF Tampa, Team 4-2, Brown Fall 2014crwdne2935289:0
USFT-BROWN-F14S4G2
crwdns2935297:026crwdne2935297:0
Be sure to include screw lengths to the nearest mm on all repair guides.
Dan Brown - crwdns2934203:0crwdne2934203:0
You don’t need to remove the battery in order to remove the motherboard. Just disconnect the battery!
matt greece - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 11,228
