Samsung Galaxy Tab 3 8.0 Battery Replacement
  1. Samsung Galaxy Tab 3 8.0 Battery Replacement, Battery - Open up the tablet: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 3 8.0 Battery Replacement, Battery - Open up the tablet: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
    Separating the back cover was the hardest part of the procedure for me (a retired electrical/software engineer). I used a large flat screwdriver blade instead of the hard plastic tool shown. Go slow all the way around the tablet and expect pops as the pieces separate. I was not able to re-connect the back cover completely, accepting a paper-thin gap about 30% around the cover, but it is secure.
    Rick Nungester - crwdns2934203:0crwdne2934203:0
  2. Samsung Galaxy Tab 3 8.0 Battery Replacement, Remove Back Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 3 8.0 Battery Replacement, Remove Back Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
    Peter how do I know which charging port I need thank you I don't know how else to reach you Tom Patrick mlc@earthlink.net all small case and no spaces thank you
    Tom Patrick - crwdns2934203:0crwdne2934203:0
    Yikes. I began carefully prizing off the screen - but when it finally came away the connector (near the top of the screen, about 1” from the right side) got ripped, so the unit is damaged beyond repair. I think it would have been helpful if your guide had warned us about this possibility and given some advice about how to make sure it doesn’t happen. I now have a broken tablet and a brand new battery, likewise of no use to me. Pretty heartbroken - the unit had been working fine, mainstay of daily use.
    goodone - crwdns2934203:0crwdne2934203:0
    For any future people repairing their tablets. DO NOT REMOVE THE SCREEN. I thought my tablet was a Tab 2, but no it was a Tab 3. No heat guns needed. I ended up cracking my screen a bit. I don’t know the extent of the damage yet, but Im probably going to get a replacement screen. You need to pop out the whole thing. Not just the front screen. The reason being that there’s a sort of metal scaffolding holding the screen and the back together. This needs to be separated to put in the new charging port.
    Matt -
  3. Samsung Galaxy Tab 3 8.0 Battery Replacement, Disconnect Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab 3 8.0 Battery Replacement, Disconnect Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  4. Samsung Galaxy Tab 3 8.0 Battery Replacement, Remove Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
    You don't have to, just be careful with battery connector.
    Kyoko Hori - crwdns2934203:0crwdne2934203:0
    You have to be very careful with the battery connector. On mine, the plug was difficult to remove from the base and I ended up breaking the connections between the base and the circuit board. Maybe use the pry tool to hold the base down while easing out the plug.
    Hugh Morrison - crwdns2934203:0crwdne2934203:0
    I just did the same thing Hugh...does that mean my tablet is trashed? Can it be repaired?
    tlibert -
    There’s also a pull tab on with label printed on the batery to make the pulling easier.
    IMI Comp - crwdns2934203:0crwdne2934203:0
crwdns2935229:032crwdne2935229:0
Peter Paoletta
crwdns2935283:009/22/14crwdne2935283:0
2 109 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 4-2, Brown Fall 2014 crwdns2935289:0USF Tampa, Team 4-2, Brown Fall 2014crwdne2935289:0
USFT-BROWN-F14S4G2
crwdns2935297:026crwdne2935297:0
To remove the battery without risk of damage, slide the corner of an old credit card under the battery in the middle at the end opposite the connector, then slide the card down under the battery to seperate the battery from the adhesive underneath. Repeat on the other side.
Hector McGillivray - crwdns2934203:0crwdne2934203:0
Also be REALLY careful when lifting up on the battery connector. It can tear away from the motherboard easily.
Lori Beth Kerns - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 40,194
