Samsung Galaxy Tab 3 10.1 Motherboard Replacement
  1. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Open Device: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your plastic opening tools, carefully start to pry apart your Samsung Galaxy Tab 3 10.1 all along the edge. Do this until the back side of the tablet can be removed.
    • Be careful when inserting the opening tools to avoid damaging the speakers on left and right sides. The picture actually show a dangerous position for the right (small) opening tool.
    • During reassembly, be careful not to insert bottom, left, nor right edges first—doing so can damage the power button, and prevent the front panel from sitting totally flush.
    • If screen is cracked like shown imagine, Place tape on screen to prevent injury.
  2. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Ribbon Cables: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove tape over ribbon cable connectors and set it to the side. Using the opening tools, gently lift the connector latches to disconnect the ribbon cables.
  3. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the ten screws securing the battery to the motherboard.
    • Make sure to keep screws in a secure location for reassembly.
  4. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull back the ribbon cables, lift up the original battery, and disconnect the battery by exerting upward pressure from beneath the battery.
  5. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Motherboard removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, pry on the edge of the motherboard lifting it up. Keeping one side lifted, insert the tip of your other removal tool and continue prying. Work the edges of the motherboard, moving the tips of the tools away from each other until the motherboard is free.
crwdns2935229:018crwdne2935229:0
Devin
crwdns2935283:010/24/14crwdne2935283:0
914 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-2, Duarte Fall 2014 crwdns2935289:0UMass Dartmouth, Team 2-2, Duarte Fall 2014crwdne2935289:0
UMASSD-DUARTE-F14S2G2
crwdns2947412:05crwdne2947412:0
How do you replace the SD card slot. I need to replace the SD card reader on the same device.
wcso845 - crwdns2934203:0crwdne2934203:0
Hello, I recently purchased a motherboard for a galaxy tab 3 10.1 16GB. I recieved it today and everything looked great. I went to install it and it does not quite fit. The right side of it overlaps just a bit raising the board above where it should be seated. I went ahead and attached all the cables the connector on the far right side of the board is in a slightly diffdrent location but with a slight bend in the ribbon cable it snapped into place, I could only get one screw to reach the threaded hole from where the board is raised due to the over size. I attached the battery and screwed the bottom side thats is away from the board and turned it on and. Everytging works fine except the camera and home button and the back wont fully snap on because the of the raised board. Not sure what to do or how to make it fit properly. Please help
Matthew Spara - crwdns2934203:0crwdne2934203:0
I also cannot get ahold of anybody in customer serice through phone cann or email so I guess ill rely on the people to help me since ifixit obviously does not care about its customers6
Will this tab 3 motherboard fit and work 100% on a galaxy tab 4 10.1??
Paul Frye - crwdns2934203:0crwdne2934203:0
Samsung you have a legal commitment to your customers for after sales service, its not all about sales and profits.
barrington - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 12,454
