Replace the USB-C Charging Port (Daughterboard) in your Samsung Galaxy S9+.
crwdns2937549:0crwdne2937549:0
crwdns2935219:0crwdne2935219:0
Hi..good morning.. I have this problem..they replaced my charging board with a new one because its not charging, and its charging again…the problem is…after they do the replacement..now the signal/network connection is gone. I’ve already did a factory reset hoping that its a software problem..but its still the same….the technician here said he dont know how tp fix this..hopefully you guys can help me with this
ys_hotel - crwdns2934203:0crwdne2934203:0
Sounds like something did not get plugged back in correctly after they replaced the daughter. Make sure and double check all connections I. The same order the video shows.
Mikeo52 -
I have the same issue, any idea how to fix the No signal symbol after changing the usb c port? Or the hardware is broken?
J.Franceschini - crwdns2934203:0crwdne2934203:0
