Samsung Galaxy S8 Active Battery Replacement
  1. Samsung Galaxy S8 Active Battery Replacement, SIM Tray/Card: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Active Battery Replacement, SIM Tray/Card: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
    You dont need to remove the SIM tray.
    Gregg Stanley - crwdns2934203:0crwdne2934203:0
  2. Samsung Galaxy S8 Active Battery Replacement, NFC Antenna and Charging Coil Assembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Battery Replacement, NFC Antenna and Charging Coil Assembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Battery Replacement, NFC Antenna and Charging Coil Assembly: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Removing the back cover of the S8 Active will compromise its waterproof seals. Have replacement adhesive on hand before you proceed, or be sure to avoid exposure to liquid if you do not replace the adhesive when you reassemble the device.
    • Remove four black 3mm screws from the outside edges of the device that hold the rubber bumpers in place using the TR6 Torx Security Screwdriver.
    • Take off the rubber bumpers from the top and bottom edges of the device.
    not needed as near as I can tell
    jason davis - crwdns2934203:0crwdne2934203:0
    You dont need to remove these.
  3. Samsung Galaxy S8 Active Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
  4. Samsung Galaxy S8 Active Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the Jimmy tool under the edge of the back cover.
    • Because of the texture of the back cover, a suction handle does not provide any grip to help lift the back cover.
    • Once the Jimmy tool is under the edge of the cover, insert an opening pick into the seam to prevent the seam from closing if the Jimmy tool slips or is accidentally removed.
    • Cut slowly around the top section of the device and be careful to avoid damaging the cables for the fingerprint sensor and camera. Avoid prying too far into the top of the device to protect the fingerprint sensor.
    • Slide the Jimmy tool down the sides of the device, separating the adhesive.
  5. Samsung Galaxy S8 Active Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the opening pick to slice through any remaining adhesive.
    • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
    • Open the back cover slightly to the point that you can see the fingerprint sensor flex cable connector.
    • The fingerprint sensor cable connects towards the top of the phone near the front-facing camera. To avoid tearing the cable, pull the back cover off gently.
  6. Samsung Galaxy S8 Active Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Active Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slowly flip the cover over and set it down on top of the rest of the device.
    • Disconnect the fingerprint flex cable using the flat end of a spudger.
    • Remove the back cover.
    • To reconnect the fingerprint sensor cable during reassembly, angle the back cover until the flex cable lines up over its socket. Use the flat end of a spudger to snap the cable in place by gently pressing straight down.
  7. Samsung Galaxy S8 Active Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove eleven 3.5 mm screws using a Phillips #00 Screwdriver.
    • Remove two 2mm screws using a Phillips #00 Screwdriver.
    You only need to remove the top seven, the rest aren't necessary to remove the battery.
  8. Samsung Galaxy S8 Active Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Active Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the NFC antenna and charging coil assembly using the flat end of a spudger.
  9. Samsung Galaxy S8 Active Battery Replacement, Loudspeaker Assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Battery Replacement, Loudspeaker Assembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Active Battery Replacement, Loudspeaker Assembly: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the loudspeaker assembly using the flat end of a spudger.
    Step nine (removing the loudspeaker assembly) did not seem necessary to replace the battery pack. Skipping this would save some time and risk. Otherwise GREAT instructions! And completed sucessfully! Sam Caldwell rev.sam.caldwell@gmail.com
    Sam Caldwell - crwdns2934203:0crwdne2934203:0
    broke 2 spudgers on this make be careful
  10. Samsung Galaxy S8 Active Battery Replacement, Battery: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Active Battery Replacement, Battery: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the battery flex cable.
  11. Samsung Galaxy S8 Active Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the heated iOpener across the top of the battery for approximately three minutes to soften the adhesive holding the battery to the device.
    • If you have multiple iOpeners, it is recommended to also put one on the screen side of the battery.
    • Alternatively, apply 1-2 drops of high-concentration (>90%) isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
    • Using too much alcohol can damage the display.
    • A hair dryer or heat gun can also be used to soften the adhesive but be careful to not overheat the battery. Also, the hair dryer/heat gun will make the metal frame rather hot to the touch, so handle it with care.
  12. Samsung Galaxy S8 Active Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Active Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to carefully pry up on the bottom of the battery with firm, steady pressure until the adhesive separates.
    • The adhesive that holds down the battery is industrial grade and is VERY difficult to separate.
    • If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
crwdns2935229:030crwdne2935229:0
Erik Mauk
crwdns2935283:001/24/19crwdne2935283:0
1,450 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S2-G1, White Winter 2019 crwdns2935289:0Cal Poly, Team S2-G1, White Winter 2019crwdne2935289:0
CPSU-WHITE-W19S2G1
crwdns2935297:011crwdne2935297:0
crwdns2947412:09crwdne2947412:0
Can I buy all of the parts on ifixit?
mikeg216 - crwdns2934203:0crwdne2934203:0
I need to do this repair. Can’t seem to find the battery on here.
jeremy wren - crwdns2934203:0crwdne2934203:0
Nice guide!
I still managed to rip the fingerprint cable tho ¯\_(ツ)_/¯
Somil Joshi - crwdns2934203:0crwdne2934203:0
I completed this, the hardest parts were: 1. When prying up the battery, the back of the screen is directly under it! Any nicks or scratches will completely damage the screen! yikes. 2. when going back through and replacing the step 8 part, make sure the pieces are completely in line and the screws are not even a tiny bit crooked.
Thanks for the guide!
Bree - crwdns2934203:0crwdne2934203:0
My wife has an S8 Active whose back cover is coming off, seems like the adhesive has failed. I’m assuming to do the repair described above you’d need to replace the adhesive on the back cover. Do you sell the adhesive strips?
Chris Coyle - crwdns2934203:0crwdne2934203:0
What type of adhesive should I use during reassembly?
sandijones - crwdns2934203:0crwdne2934203:0
The battery is not charging
I have chang it but still not
Israel Jerry Nkrumah - crwdns2934203:0crwdne2934203:0
So nice i am so satisfied
Kelvin - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 100
crwdns2942667:0crwdne2942667:0 24,105
