Samsung Galaxy S5 Screen Replacement
crwdns2942287:0crwdne2942287:0For the official iFixit guide to repair your Galaxy S5 display, click here. The guide you are currently viewing is duplicate content, archived here for historical purposes only.
crwdns2942269:0crwdne2942269:0
crwdns2942337:0crwdne2942337:0
crwdns2944105:0crwdne2944105:0
Remove the rear case by using moderate force to pry the divot on the left of the rear facing camera with a plastic opening tool or your fingernail.
Continue to lift the case, working your way around the perimeter until the entire rear cover is removed.
Lift the battery upward with your finger or plastic opening tool by pushing on the notch located on the bottom of the battery.
Remove the battery from the phone.
Gently slide out the SD card using your fingernail or a plastic opening tool.
Place the iOpener in the center of the microwave.
Heat the iOpener for one minute on the highest power setting.
Remove the iOpener from the microwave, holding it by the printed tag.
Lay the iOpener flat on the bottom of the device, directly over the home button. Smooth the iOpener along the surface to ensure good contact with the device. Leave the bag on the device for around 90 seconds.
Repeat the process laying the bag on the left and right edge of the screen.
Use a light amount of force when removing the screen.
Starting at the top of the device, work the plastic opening tool under the screen. The top of the device has the Samsung logo and headphone port.
Start separating the screen from the glue. Work your way around the screen until the glue is no longer holding the screen in place.
During this operation I destroyed display. Display was glued from back to the phon. So if you even softly touch it, it will crack.
Start lifting the screen from the top. You will see a black ribbon cable attaching the display to the motherboard. Use the plastic opening tool to lightly detach the connector.
As I lifted it, the display panel cracked in half. It is very fragile.
Continue to lift the display. You will notice a black cable connecting the home button to the motherboard.
Use the plastic opening tool to pry the home button off. Moderate force is required.
When gluing the home button back to the display, is there a particular glue I should use?
crwdns2935229:068crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:011crwdne2947412:0
Is there a way to take off the front glass ONLY? With the S4 the front glass was ONLY attached to a cable for the buttons on the bottom. Any help would be greatly appreciated.
Or the galaxy S5 as well?
How do I get a new light to light up my screen as I'm hoping I can use it n just change the light
I would also know if the iopener will allow me to take off only the glass and NOT the digitizer with it. If anyone knows, please share.
My S5 fell down and and after some hours there appears ink on the screen. Please what is wrong? Do I need to change the whole screen or is there a unit that brings out ink and have to change only that unit only?
Hi did you find out what causes this? i had the same issue my phone fell and the scree looks like ink dropped inside of it
jochmejr -
Pls help me my mobile sumsung galaxy s5 flikering how to solved
I got my ifixit kit for the galaxy s5, but after a month, the screen assembly lifting on one corner. I bought as a kit, fully assemble. So any other glue or tape to try ?
lol the digitizer is the glass and there is no ink in displays your lcd is fukd you need to replace the entire screen assembly
غالي جدن ما يير 90
my s5 has small crack on left hand corner and screen is black. it switches on though
Nice work for my phone setting
BhupSinghBhadu Baf - crwdns2934203:0crwdne2934203:0
Thanks very much A better replace ment
